{Clogged fuel filter or weak fuel pump}
Old Feb 12, 2005 | 09:50 AM
SlAmMeD 91 HaTcH's Avatar
Default {Clogged fuel filter or weak fuel pump}
Today I came out to install my air fuel ratio autometer gauge on my civic 91 stock motor and i spliced a little peice of wire from my o2 wire and i had the gauge working fine then i go back in the car and hitt the accelarator and was a bigg bogg and i let go and it idledd hitt the throttle again another boggg then it died then it wouldent start check the main relay it was fine and i went to the store sprayed some starter fluid in there started rigt up real quick then shut rigt of when it sucked it all up, So im guessing the fliter must be clogged of something or the pump is weak but its not shot because i can hear it come on when i turn the key to the 2nd postive but it will only run with the ehtier was working fine yesterdayy immm stumped and were is the fliter located 91 civic std dpfi BUMP BUMP BUMP NEED HELP THANKS ALOT....
Old Feb 12, 2005 | 07:45 PM
Default Re: {Clogged fuel filter or weak fuel pump} (SlAmMeD 91 HaTcH)
ANYTHING???????BUMP..
Old Feb 12, 2005 | 08:09 PM
NJIN BUILDR's Avatar
Hmmmmm...worked ok until you installed the guage?
Old Feb 12, 2005 | 08:33 PM
Default Re: {Clogged fuel filter or weak fuel pump} (NJIN BUILDR)
yehh like i guess u can say the car was fine until i started fooling with the gauge 2 get it 2 work but i unpluged the gauge so iunno whats sup i can hear the fuel pump turn on im still thinking clogged filter because it just alll of a sudden acted like suttin clogged up so iam going 2 see if i have some pressure up front the main fuel line see if any gas is comeing 2 it but it is def a fuel problem as soon as u tap a spary of starting fluid starts rigtt up....??
Old Feb 13, 2005 | 07:02 AM
anything??BUMP BUMP..
Old Feb 13, 2005 | 01:36 PM
? anybody help i need 2 kno asap thank you..
Old Feb 13, 2005 | 04:12 PM
Spoolin93si's Avatar
Replace the fuel filter, they are like no more than $25 from AutoZone. If you can't find the fuel filter on your car its mounted on the firewall to the left of the intake manifold. It is a black cylinder with a hose going from the filter to the fuel rail.
Old Feb 15, 2005 | 01:41 PM
Default Re: {Clogged fuel filter or weak fuel pump} (Spoolin93si)
Hey just replaced the fuel filter with a napa gold filter the old one had plenty of pressure so im pretty sure my pump is good i can hear it when i turn the key up now my only guess is the main relay because it still wont start it cranks and only runs on starting fluid once it sucks the starting fluid it dies down real smooth like...??? help plz later..
Old Feb 17, 2005 | 06:55 PM
deeweewoo's Avatar
You didnt completley disconnect any of the wires from your O2 sensor did you?
If you did the computer thinks it is running to rich and is not supplying the fuel.
Old Feb 17, 2005 | 07:26 PM
flymecourageous's Avatar
Default Re: {Clogged fuel filter or weak fuel pump} (deeweewoo)
whats your fuel pressure
Old Feb 18, 2005 | 08:32 AM
Default Re: {Clogged fuel filter or weak fuel pump} (flymecourageous)
Umm im not sure about the pressure but i haver been told that it is the relay but i thought the relay makes the pump turn on but yesterday i got it 2 stay on and drive down the street but my air fuel gauge is pinned on rich even when i rev it then it hitts stoich then back 2 rich on idle and black smoke when u rev it then i let it idle then it acted up and bogged and shut of like it wasnt gettin gAS again like the fuel pump stopped or suttin..bump
Old Feb 18, 2005 | 05:41 PM
deeweewoo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deeweewoo &raquo;</TD></TR><TR><TD CLASS="quote">You didnt completley disconnect any of the wires from your O2 sensor did you?
Old Feb 19, 2005 | 11:05 AM
dornon13's Avatar
Give us a step by step process on how you installed the gauge, since this is when you started having problems i would be willing to bet you somehow goofed up the install.Also are you getting and CELs if so check them out before you post again
Old Feb 19, 2005 | 11:18 AM
mmuller's Avatar
Mad Scientist
Default Re: {Clogged fuel filter or weak fuel pump} (dornon13)
like take the gauge that like you like installed to see if it works
Old Feb 19, 2005 | 12:25 PM
This is how i installed it,I already had a little spiced wire on myu o2 wire and i wraped the purple wire from the air fuel gauge then black ground and red 2 1 of my fuses that my tach is hooked up to the gauge works when the car is running.. so that should be the rigt way. Um i think it is just my fuel pump because it dont wanna stay on unless i keep spraying gas in the throttle body dpfi the car started the problems the day i did the gauge i mean i have no idea whats wrong i have no cel blinks, i have no check engine lights, but how come before i had a cel 16 for fuel injector and i took out the little 12v 4 prong thing that i first thought it was the relay then put it back in and reseted my ecu and the code 16 went away, but yesterday i had the car staying on for a while but if u let it idle it seems as if the pump shuts of and the motor is only running of the little bit of gas that is left in the manifold then it will bog then die and will only start up iif u put gas in the TB,ppl have been saying its the main relay but i hear it click and i hear my pump turn on, on the 2nd nocth were all the dash ligts light up so imm really stumped , its like some were in the line fuel is working then fuel gets weak and wont runn no more and im haveing a rich problem when it did run before when it had the code 16 it had the wrx idle and was real choppy sputter rpms when cold and idle was very shitty all of a sudden that went away and now its not given no codes no check lights i need help.. and the ecu is on because when i turn the key up i se it flash once then thats alll... get back 2 me
Old Feb 19, 2005 | 05:23 PM
ENDGAME's Avatar
try this .... remove the negative terminal from the battery ... leave it off for like 10 min, while it is off remove the gauge and reconect the terminal after 10 min ..... try that it may just be the gage.
Old Feb 19, 2005 | 07:16 PM
n3tfury's Avatar
those are the longest sentences i've ever seen in my life.
Old Feb 19, 2005 | 08:40 PM
dornon13's Avatar
Default Re: (n3tfury)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ENDGAME &raquo;</TD></TR><TR><TD CLASS="quote">try this .... remove the negative terminal from the battery ... leave it off for like 10 min, while it is off remove the gauge and reconect the terminal after 10 min ..... try that it may just be the gage.</TD></TR></TABLE>
yes try that.
if that doesnt work check your connections, i think your ecu is getting wierd readings which would make it run horrible or not at all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlAmMeD &raquo;</TD></TR><TR><TD CLASS="quote"> i wraped the purple wire from the air fuel gauge</TD></TR></TABLE>
This doesnt make me think you took good care in wiring it. Also make sure you have a GOOD ground. if you have to, connect it to the battery(neg) and see if it helps.
I seriously doubt your pump or relays or bad but it could be a problem i guess...but i would put my money on the wiring
oh yeah one more thing i was reading the install directions and it says this
"Connect to the oxygen sensor wire. Connect to the vehicle wiring harness, not oxygen sensor since some oxygen sensors use shielded wire"
Which did you splice in to?
ps. please try to type a little clearer sentences.
Old Feb 22, 2005 | 10:25 PM
deeweewoo's Avatar
Did you ever get it figured out?
Old Feb 23, 2005 | 12:02 PM
Na i havent yet iam just going to replace the relay..And if not that then i guess I will get a new pump to because i dont no nuttin else wrong...1question how come before I had the code 16 for fuel injector and it went away all of a sudden...weird.
Pr0ject93hb
Feb 25, 2007 08:34 AM
racingant
Jul 24, 2005 08:41 PM
Fatty_1775
Dec 3, 2004 07:59 PM
ewing86
Oct 20, 2004 04:35 PM
hairyferry2000
Jul 19, 2004 07:50 PM
