Cruise control question
Old Feb 12, 2005 | 09:15 AM
jeef84's Avatar
Default Cruise control question
Does anyone know of the stock ex cruise control module will work with the teg p78 comp? My cruise control hasn't worked since I swapped my engine in, and I was wondering if this could be the cause. Btw, it's a 95 EG EX with a 94 b18b1 swap.
Old Feb 12, 2005 | 10:05 AM
5lugcivic's Avatar
Default Re: Cruise control question (jeef84)
it should if the LS that it came off has it... my jdm p72 cruise works on my EG Si...
Old Feb 12, 2005 | 11:01 AM
TeamNextGenChris's Avatar
the cruise system has it's own ECU,so it shouldn't be affected by it.i've done several swaps in cruise cars and had no problems,although i've never used that particular ECU.i've also seen factory non-cruise cars that people have added cruise to with the stock motor still.
what exactly is it doing?does the cruise light still come on when you try to set it?
Chris
Old Feb 12, 2005 | 11:11 AM
jeef84's Avatar
Default Re: Cruise control question (TeamNextGenChris)
The cruise light doesn't come on when I press the button, I checked all of the connections, and they seem to be fine. Am I just going to have to replace the module?
alecmesa96
Dec 31, 2017 05:06 PM
triple beam
11
Jun 13, 2014 08:31 AM
22's and Man Boobs
Nov 1, 2007 05:44 AM
1995sir
Apr 11, 2006 09:50 AM
