drum brakes VS ME round 2
ok my lazy *** roomates won't help me bleed my brakes.
Roomates won't help me with bleeding brakes.. bastards what comes around goes around. <just waiting for justice>
Ok... i was at work yesturday and i was trying to figure out how to do this.
once you push in on the brake the fluid is sent through the line. <i tried to uncover the bleeder valve with the rubber cap nothings coming out??? so if pushed my piston out and misarranged my shoes... so i had to set up again.>< i took out the bleeder valve completely and try to see what's the problem i don't know it there is a hole in it. but all it does is come to a sharpe point on the other side.>
back to the begining where i push the brake with the stem off and place a weight on the brake. screw the cap in. release the brake and repeat until the air out of the brake fluid line?
sound good but have not tried.
the easiest part is the spring once you know how to manipulate them to work. it's just since roommates won't help i need to find a monkey and train it to push on the brakes.
Can i barrow someone's monkey?
sorry for the error above i have a sinus cold.
thanks for the help.
Re: drum brakes VS ME round 2 (Luserkid)
yeah i was thinking about that.
but doesn't the stock bleeder valve have a hole in it.
if it does were talking Um at best.
hermtm2
05-08-2009 10:33 AM
