what could be wrong with my horn?
Old Feb 12, 2005 | 08:44 AM
RACEPAK's Avatar
Default what could be wrong with my horn?
hello everybody
what could be wrong with my horn? its not working !
the fuse is ok
the horn switch is ok. i tested it with a voltmeter
the the horn itself is working ( i tryed it on the battery)
what could be wrong?
best regards moshik galimidi
Old Feb 12, 2005 | 09:29 AM
mustyrules's Avatar
sometimes those horns are grounded by the mounting bracket. maybe you are not getting a good ground. look into that.
Old Feb 12, 2005 | 10:28 AM
RACEPAK's Avatar
Default Re: (mustyrules)
thanx but its not a ground problam.... anybody else?
Old Feb 12, 2005 | 04:19 PM
Lord Helmet's Avatar
Default Re: what could be wrong with my horn? (RACEPAK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK &raquo;</TD></TR><TR><TD CLASS="quote">hello everybody
the fuse is ok
check the wire going from the horn switch to the horn itself. see if it has any constant power going to it when you push the horn button. Sounds like a loose connection somewhere in there. Also check the horn relay which is under the dash where the rest of the fuses are at.
thatasiankidtony
Audio / Security / Video
Nov 7, 2006 02:18 PM
9500redline
Oct 28, 2005 06:25 PM
romoracing
Aug 17, 2005 07:09 PM
Fly1865
Jun 18, 2004 05:48 PM
