one day tranny is fine next day pops out of gear help
Old Feb 11, 2005 | 10:44 PM
dcsports's Avatar
Default one day tranny is fine next day pops out of gear help
read title i have new clutch with prolly only 4 k on it
well it first started off poping out of first gear.. then later on i tried to shift all u hear is my gears grinding nasty sound then later second gear is also gone my second gear is worse it goes into gear once in a blue moon what could my problem be ???
Old Feb 11, 2005 | 11:38 PM
dcsports's Avatar
Default Re: one day tranny is fine next day pops out of gear help (dcsports)
Old Feb 12, 2005 | 01:36 AM
nub.96ek's Avatar
It is likely to be your synchronizers... you will have to replace the synchros or the whole tranny - whichever is more practical for your budget.
Old Feb 12, 2005 | 01:56 AM
ZeRo AsSault's Avatar
might be the syncrhos or it might be the slave cylinder, also check if you have fluid
Old Feb 12, 2005 | 03:50 AM
EE_Chris's Avatar
Did you make sure to re-adjust the clutch pedal after initial installation (the push-rod from the pedal into the M.C.)? Have you tried it again, just to be sure? The rod should have a small amount of wiggle to it.
Also make sure your fluid level is correct - or that there is fluid in there at all.
Old Feb 12, 2005 | 06:28 AM
dcsports's Avatar
Default Re: one day tranny is fine next day pops out of gear help (EE_Chris)
[QUOTE=EE_Chris]Did you make sure to re-adjust the clutch pedal after initial installation (the push-rod from the pedal into the M.C.)? Have you tried it again, just to be sure? The rod should have a small amount of wiggle to it.
that i dont remember doing at all, but the fluid levels are good can anyone explain that push rod thing to me?
Old Feb 12, 2005 | 06:39 AM
EE_Chris's Avatar
Very simple - look up under your dash and locate the clutch pedal. You'll see a U-shaped metal piece (attached to the pedal) along with a rod that threads into it and a lock nut to keep it in place.
So first off - just look under, locate it and jiggle it - can you? If you can't, then just loosen the locknut (12mm), turn the rod to loosen it up, then tighten up the nut - just make sure there is some wiggle in there.
ballisticej1
Jan 4, 2010 08:54 PM
The Phil
Mar 18, 2005 08:27 AM
B18cteg
Jul 3, 2003 10:18 AM
tilt
Oct 7, 2002 01:22 PM
