Straight Pipe..2.5 or 3.0?
Old Feb 11, 2005 | 10:33 PM
JDM00SI's Avatar
Default Straight Pipe..2.5 or 3.0?
im currently running a b16a2 w/ bolt ons. I was thinking about getting either 2.5 inch pipiing or 3 inch piping for it. Although im afraid if i get caught without a catalyc convertor. i heard the fines can hit 3,000 dollars, not worth it at all. I was htinking maybe getting the pipiing and then a hi flow cat. i currently have an apexi n1 cat back, am i going to have to get rid of the apexi and buy a muffler to stick on the tip or is there a way i can keep the apexi with getting maximum gains? Also this straight pipe will give me high end speed right? thanks
Old Feb 11, 2005 | 10:34 PM
JDM00SI's Avatar
Default Re: Straight Pipe..2.5 or 3.0? (bigbeasta4)
bump
Old Feb 12, 2005 | 07:33 AM
JDM00SI's Avatar
anybody?
Old Feb 12, 2005 | 07:47 AM
mmuller's Avatar
Mad Scientist
2.5
Old Feb 12, 2005 | 09:30 AM
thatbluecrx's Avatar
Default Re: Straight Pipe..2.5 or 3.0? (mmuller)
definitly not 3
Old Feb 12, 2005 | 09:55 PM
JDM00SI's Avatar
Default Re: Straight Pipe..2.5 or 3.0? (thatbluecrx)
how will it sound ricey with the 2.5 piping? what is the stock piping on my si? will i need to buy a muffler to weld onto the straight pipe? im currently running a apexi n1 cat back, is the piping from the cat to the muffer on that exhaust system 2.5 or is it stock size? thanks alot
Old Feb 13, 2005 | 06:44 PM
JDM00SI's Avatar
bump
Old Feb 13, 2005 | 07:14 PM
socki18's Avatar
dude do 2.5 or itll suck ***, unless you got a turbo or s/c. then go 3
Old Feb 13, 2005 | 07:42 PM
JDM00SI's Avatar
Default Re: Straight Pipe..2.5 or 3.0? (socki18)
also wat is a s/c?
Old Feb 13, 2005 | 08:36 PM
socki18's Avatar
dude, im running some shitty *** header, into a pacesetter hi-flow cat, and then my 2.5" magnaflow cat back on my b16a. it sounds real deep and not ratty. if you go with a straight pipe itll sound like a shitty ratty car.
thats just what i have. your car, you run what you want. im just sayin if you run straight pipe itll sound like a damn cavalier with a "cool" apc muffler
Old Feb 13, 2005 | 09:16 PM
RangerJoe's Avatar
your stock pipe is probably somewhere between 1.5 and 2" cast iron.
2.5" SS would be just great for you.
s/c = supercharger
Old Feb 13, 2005 | 09:34 PM
JDM00SI's Avatar
Default Re: (RangerJoe)
what would be a good high flow cat that you perfer? thanks
Old Feb 14, 2005 | 03:47 AM
RangerJoe's Avatar
magnaflow makes a good 2.5" in/out high flow
the part number is 94006
Old Feb 14, 2005 | 06:37 AM
mountaindewguy's Avatar
get 2 1/4 or 2.5. if you go to 3 you'll get backpressure and it'll sound like $h!t. but if you go force induction get the 3
Old Feb 14, 2005 | 08:07 AM
SuzukaBlueAP2's Avatar
Default Re: (mountaindewguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mountaindewguy &raquo;</TD></TR><TR><TD CLASS="quote">get 2 1/4 or 2.5. if you go to 3 you'll get backpressure and it'll sound like $h!t. </TD></TR></TABLE>
He'll get backpressure if he gets 3" piping?!? He'll have less back pressure with a larger pipe, it'll still be there, just less.
Anyways...for a B16A2 that is only mildy modded with bolt ons, 2.5" ID piping will be more than sufficient. 2.5" piping will support almost 300whp, which you won't be close to.
Old Feb 14, 2005 | 08:50 AM
mugenTak's Avatar
Default Re: (ScreaminTeg)
Random Technology makes good high flow cats.
Project.Jdm
Jan 2, 2008 07:20 PM
gsrcivic1992
Jan 21, 2005 08:53 AM
o d i e e
Oct 16, 2003 12:17 PM
hmongboyLS
Jul 24, 2003 10:01 AM
cocopuffz ny
Oct 8, 2002 02:47 PM
