which gsrs here are making ~200whp NA?
Old Jan 16, 2002 | 11:09 PM
comptechgsr's Avatar
Default which gsrs here are making ~200whp NA?
and whatta ya got?
Old Jan 16, 2002 | 11:13 PM
ITR 2K's Avatar
Default Re: which gsrs here are making ~200whp NA? (comptechgsr)
Yeah, I'm curious as well.
Old Jan 16, 2002 | 11:32 PM
GQ 05YellowEVO8's Avatar
Default Re: which gsrs here are making ~200whp NA? (ITR 2K)
200+ WHP expected in the house....or bust with my mods.
Old Jan 17, 2002 | 07:04 AM
madchiller's Avatar
Premium Member
25 Year Member
i do.... oh wait.. that was in my dreams!
Old Jan 17, 2002 | 07:12 AM
smiloo's Avatar
New User
Default Re: which gsrs here are making ~200whp NA? (FuknGSR)
Did the AEM Cam Gears do anything for you? Did you do a dyno before and after the install? I heard that it makes idle rough. Is this true?
Smiloo
Old Jan 17, 2002 | 02:22 PM
thegrinch's Avatar
I am shooting for the big 200 ALL MOTOR. GSR. this is rather difficult in a daily driven car especially with the stock throttlebody. I am currently at 190whp but getting retuned next week in time to make some runs in it next weekend. hopefully i will hit 13's on street tires. ran 14.08 @98.60mph last weekend. what ever you fellows do don't buy the skunk2 cams!!!! WARNING.
Old Jan 17, 2002 | 02:57 PM
StinkyTofu's Avatar
Default Re: which gsrs here are making ~200whp NA? (thegrinch)
the grinch-if you don't mind me asking, but what kinda set up do you have?
Mr. Softee's Avatar
here is my setup:
Skunk2 Intake Manifold (p/p)
JDM ITR header (p/p)
Custom p28 ECU
p30 pistons (25 oversized)
b18c1 Block Rebuilt bored 25 over
GSR Head
Ferrea Valves
5 Angle valve job
Jun 3 Cams
STR cam gears
Short ram intake
2.5" exhaust
B/M FPR / Gauge
Milled Head (26 thou)
2.5" Cat
ITR Clutch / PP / Throw out bearing
Shaved Flywheel
Portflow Valve Springs
i hope to hit 200whp
Old Jan 17, 2002 | 03:02 PM
thegrinch's Avatar
sound like goldjungsr can give me a run!!! wew have almost the same set up other than the cams. I use to have the skunk crap i mean skunk2 intake manifold but changed my mind because of the loss of torque on the bottom end. however it did get me more overall hp.
Old Jan 17, 2002 | 03:30 PM
SIINSI's Avatar
Default Re: which gsrs here are making ~200whp NA? (94goldjungsr)
here is my setup:
Custom p28 ECU
GSR Head
Ferrea Valves
5 Angle valve job
Jun 3 Cams
STR cam gears
Short ram intake
2.5" exhaust
B/M FPR / Gauge
2.5" Cat
Shaved Flywheel
Sounds like an easy 200 to me Nice man!
Miguel
Old Jan 17, 2002 | 03:34 PM
Mr. Softee's Avatar
Default Re: which gsrs here are making ~200whp NA? (SIINSI)
thx, btw, this is 97lstegra / azteg... just changed this name to reflect the new car i got umm... 6 months ago
Old Jan 17, 2002 | 03:38 PM
ingrate's Avatar
25 Year Member
what's wrong with the skunk2 cams?
Old Jan 17, 2002 | 03:49 PM
thegrinch's Avatar
Default Re: which gsrs here are making ~200whp NA? (In7egrity)
look at my post on the thread of reliable skunk2 cams.
Old Jan 17, 2002 | 05:05 PM
1fastGSR's Avatar
New User
mine is... sorry, my sig says 176 whp
Old Jan 17, 2002 | 05:46 PM
Cow's Avatar
Cow
Default Re: which gsrs here are making ~200whp NA? (1fastGSR)
1fastGSR, you hit 200 with ITR cams? Or were you being sarcastic
Old Jan 17, 2002 | 07:16 PM
GZR4DR's Avatar
Default Re: which gsrs here are making ~200whp NA? (Cow)
201.9 whp with ITR cams. That is what i hit on my GSR motor. I had a:
stock GSR bottom end (never touched)
Prospeed race head
JDM 4-1 header
ITR intake manifold
AEM gears
P-28 prospeed race ecu
vafc
fuel regulator and guage
filter on a stick
HKS flywheel
Hyper clutch
Open exhaust
No belts cept alternator
I also hit 216whp with custom race cams. If you want to see the dyno sheet, go to http://www.prospeed-performance.com and look under project vehicles. The integra made the 201whp with the ITR cams, and the civic made the 216whp. Both have dyno sheets. I don't mind if anyone wants to link them either, i'm just to lazy at the moment.
Old Jan 17, 2002 | 07:39 PM
unKnown's Avatar
Default Re: which gsrs here are making ~200whp NA? (GZR4DR)
i think cresent of cspeed racing is making 200 whp in his b20/vtec gsr
not sure though, don't quote me! but with a 1320 time of 13.4 *i think* hes making 200 whp
Old Jan 17, 2002 | 07:57 PM
Vtec integra's Avatar
mine is:
act 6 puck clutch
lightenned stock flywheel
balanced bottom end
J E12:5:1 compression pistons
eagle rods
port polish 3 angle valve
ferrera stainless steel valves
custom tubed intake manifold
holley 68mm throttle body
270 cc injectors
aem feul rail
b and m feul pressure regulator
b16 tranny
aem pulleys
skunk 2 cam gears
toda b specs
toda valve springs
stainless steel retainers
obd2 to obd ! conversion
sohc vtec reprogrammed to toda program by pit crew
denso plugs
blaster coil
msd wires
aem cai
crappy dc 4-1 header (port matcched)
stock cat
thermal r and d exhaust
[Modified by Vtec integra, 8:59 PM 1/17/2002]
Old Jan 17, 2002 | 08:17 PM
2005 TSX's Avatar
Default Ok...
How about this...
So far, my car is stock engine wise. Roughly, how much money would it take to make my engine +200hp. And if I was +200hp, would I still be able to pass smog here in "strict" California?
Old Jan 17, 2002 | 09:15 PM
3-4 grand and no you won't pass emissions unless you have hook ups on the inside like i do
Old Jan 18, 2002 | 04:51 AM
Lip's Avatar
Lip
94gsr built
last dyno running out of fuel was 241.9hp with 159.1ft lbs to the wheels.
iwannarace
21
Dec 11, 2011 07:40 PM
SonicB
Jul 21, 2010 01:12 PM
roudiiboii
Jun 7, 2010 10:39 PM
usdm_dc2
Oct 3, 2007 09:46 AM
boosted k20
10
Jul 29, 2005 11:00 AM
