ITR (length) rods with LS block/crank
anybody seen success with this, basically another .025" higher than stock piston height in an LS block. seems that there would be some benefits/drawbacks but just curious
seems like the extra .9mm on the rod could help. Im curious about this for use in an 84/89 setup to make about 11.5:1 as a street motor revving 8800-9000rpm.
Kind of expensive for .025".If I was to go with a custom rod I think I would go for the +.100" and a custom piston with a 1.000" comp, height.the ITR rod is too narrow to run on the LS crank.You would loose to much oil pressure with all that side clearance.
Glenn
Glenn
