if you have a drag III for sohc and swap to B series, can u use the turbo by changing the manifold o
Old Jan 16, 2002 | 10:56 PM
hobo79's Avatar
New User
Default if you have a drag III for sohc and swap to B series, can u use the turbo by changing the manifold o
can you just change the drag gen III turbo kit for a sohc civic 92-00's manifold and still use the turbo if you swap a B18c1 or any b series for that fact?
Old Jan 16, 2002 | 11:40 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: if you have a drag III for sohc and swap to B series, can u use the turbo by changing the manifo
Yes, as long as you keep a turbine housing a T3...
art
Old Jan 16, 2002 | 11:41 PM
dustin's Avatar
You can but I think all the sohc kits come with t04b compressors so you might want to swap the turbo out someday to match the new motor. But it will all bolt up w/ a new bseries manifold.
Dustin
Old Jan 17, 2002 | 06:24 AM
DragII's Avatar
the B16 uses the same turbo as the SOHC kits....I just did this exact same thing...you will need a new manifold, and a new down pipe.
vboy714
May 17, 2006 04:49 PM
1320DRAGWORKX
Jul 26, 2005 07:15 PM
tvrsir
Jan 2, 2003 04:00 PM
