Cam(s) questions
Old Feb 11, 2005 | 06:16 PM
98civic94gsr's Avatar
Default Cam(s) questions
Right now my jdm b18c has:
lightweight flywheel(11 lbs)
lightweight crankshaft pulley
stage 1 clutch kit
itr header
2.5 inch exhaust
short ram air intake
I want to throw a set of cams and intake manifold on this car.
What cams and intake manifold would yeild the best performance for my setup. I don't want anything to drastic cuz I'm a newbie and ain't much of a tuner.
Also if you see some other mods that would yeild some more horsies let me know...Anything let me know....
Help me out guys,
thanks,
98civic94gsr
Old Feb 11, 2005 | 06:56 PM
SpoonFull's Avatar
Default Re: Cam(s) questions (98civic94gsr)
if u did some searching u'd prolly find what u need.
but in any case.. you could look into type r cams, blox spec a cams, or skunk 2 cams. for the stage 2/spec b you would need to upgrade your valve train, retainers and valve springs, might want to get adjustable cam pulleys also.
for some extra ponies, you could look into a VAFC then you should tune your car with the cams installed.
port and polish your head while your at it too.
Old Feb 11, 2005 | 06:59 PM
jakeiscool's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonFull &raquo;</TD></TR><TR><TD CLASS="quote">if u did some searching u'd prolly find what u need.
port and polish your head while your at it too.</TD></TR></TABLE>
Hold on.....Vafc is a big I wouldnt do stage 2 cams unless you have your head milled.
Old Feb 11, 2005 | 07:11 PM
gsr-2nr's Avatar
Default Re: Cam(s) questions (JakeIsCool)
id leave the intake mani alone u already have a pretty good one
Old Feb 11, 2005 | 07:14 PM
Default Re: Cam(s) questions (gsr-2nr)
So what should I do. Get stage 1 cams? If I just get stage 1 cams would you guys also get new retainers and springs? Anybody got stage 1 cams and the other stuff I need?
Wouldn't a skunk 2 im be better than the snail?
Old Feb 11, 2005 | 07:17 PM
jakeiscool's Avatar
Banned
Stage 1 cams you most likely wont need new valvetrain. Skunk2 intake manifolds make good top end power, I would leave your IM stock.
Old Feb 11, 2005 | 07:20 PM
So what would my horsepower be roughly with the mods listed and stage 1 cams?
Flame away.....
94civicdeleon
Jun 19, 2009 11:03 AM
WhyTry?
Honda Civic (2006 - 2015)
10
Mar 1, 2009 06:25 PM
korndog
Jun 7, 2007 07:04 PM
eg_hybrid
Apr 30, 2001 12:20 PM
