When replacing a headgasket what is needed?
Old Feb 11, 2005 | 05:27 PM
B16Civic93's Avatar
Default When replacing a headgasket what is needed?
I'm about to replace my headgasket on my b16 just wondering if there are any washers, or any other gaskets needed besides the headgasket when replacing it?
Old Feb 11, 2005 | 07:53 PM
sickerhatch's Avatar
Default Re: When replacing a headgasket what is needed? (B16Civic93)
you might as well do the basics like timing belt,water pump,cam seals,and if you have a vtec head theres a small dowl pin and o-ring under the middle cam cap.also you will need an im gasket if you remove it.
Old Feb 14, 2005 | 06:14 AM
B16Civic93's Avatar
Default Re: When replacing a headgasket what is needed? (sickerhatch)
where would be a good place to get the small dowel pin and o-ring? also where is a good place to get new cam seals? one of mine is leaking now. where can i get a new water pump and timing belt? any good websites to buy these parts off of?
Old Feb 14, 2005 | 10:46 AM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16Civic93 &raquo;</TD></TR><TR><TD CLASS="quote">where would be a good place to get the small dowel pin and o-ring? also where is a good place to get new cam seals? one of mine is leaking now. where can i get a new water pump and timing belt? any good websites to buy these parts off of?</TD></TR></TABLE>
http://www.hondaautomotiveparts.com
Old Feb 14, 2005 | 05:58 PM
B16Civic93's Avatar
Default Re: When replacing a headgasket what is needed? (PrettyLude)
anything else? i really couldnt find anything that i was looking for on that website, unless i just wasnt looking in the right places, i dunno any help is appreciated.
Old Feb 15, 2005 | 10:20 AM
PrettyLude's Avatar
if front main seal is leaking or need to be changed, change it, that's pretty much it besides the stuff sickerhatch said before
Mike VR6
35
Mar 2, 2007 03:23 AM
XplodeTeg
Sep 5, 2006 03:46 PM
mikeycivic
10
Feb 2, 2006 01:08 PM
B18Redline
Nov 6, 2004 10:26 AM
Si_LuDer
Sep 15, 2003 07:33 AM
