How to adjust luminas?
Old Feb 11, 2005 | 04:34 PM
C-RICKS's Avatar
Default How to adjust luminas?
Hi guys.
i just bought a couple of tokiko luminas for my 90 CRX for $70. total.
They look legit and stuff. Pretty damn new looking too. My question is...
Are they white?
And how do i adjust them?
Thank you,
Rick
Old Feb 11, 2005 | 04:42 PM
XrcR6's Avatar
Default Re: How to adjust luminas? (C-RICKS)
Tokico Illuminas are typically white bodied, the non-adjustable are painted blue. They should or at least they used to, have it written in red writing on the body...
You need a small flat bladed screwdriver for the top, 1-5 is softest to hardest.
Old Feb 11, 2005 | 04:46 PM
C-RICKS's Avatar
Default Re: How to adjust luminas? (XrcR6)
What do i do?
Just put it in the little slot and turn?
Will i feel notches or something? Cause i don't think that they are numberred.
Thanx in advance!
Old Feb 11, 2005 | 04:57 PM
XrcR6's Avatar
Yes, around the slot for the screwdriver, it is numbered. There should be detents, that you will feel.
This is on a Hachiroku application, but the area in question should look the same:
Old Feb 11, 2005 | 05:32 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
If you don't have the top two pieces to adjust it,
Supposebly Tokico will send you new ones for free;
[from what I have heard..]
I put rubber vacuum caps over the shock studs so if the adjuster comes off
the pieces won't get lost..
Old Feb 11, 2005 | 05:42 PM
rsca_crx's Avatar
Default Re: How to adjust luminas? (88DXCRX)
you can still adjust it w/out the caps (or if you manage to break the top of your very old shaft off when you put the hex-key in, leaving you with no "hole" to put the adjuster in- don't ask me how i know)
the little d-shaped metal shaft is what turns. look at the pic above and you can see where the numbers are 1=full soft, 5=full firm. turn it to full soft (counter-cockwise), and then go the right distance clockwise to what you are looking for.
Old Feb 12, 2005 | 12:54 PM
C-RICKS's Avatar
Default Re: How to adjust luminas? (rsca_crx)
oh ok!
So i'm actually turning just the screw while holding the hex'd nut from moving.
thanx alot guys!
1LowSol
Jan 17, 2009 12:24 PM
JoshuaVTEC
Apr 21, 2008 03:48 PM
sohcvtec97
Oct 16, 2006 09:17 AM
rice a roni
Mar 16, 2005 10:14 AM
lude19
Nov 18, 2002 12:44 AM
