Oil spots are showing on valve cover
Ever time I open up the hood, I see the valve cover having bigger spots of soaked oil on it. It seems to be coming from a bolt right behind the spark plugs more and more. What should I be replacing here?
If I understand correctly, the oil is leaking from the valve cover grommets. They're the little rubber parts that have metal washers under the nuts that hold your valve cover on. Replace these, the grommets are about 3 bucks each at your local honda deal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shaguar47 »</TD></TR><TR><TD CLASS="quote">Ever time I open up the hood, I see the valve cover having bigger spots of soaked oil on it. It seems to be coming from a bolt right behind the spark plugs more and more. What should I be replacing here?</TD></TR></TABLE>
What is a CX? I've never heard that trim applied to 88-91 models... Maybe this will help:
http://www.hondapartssource.co...ch=no
Is the bolt you're referring to one of the chrome nuts (#12)? Then it might be the washer/grommet underneath. Or maybe you just need to tighten it.
Yeah its the valvecover washers.. there under the nut that holds the valvecover on.
I was missing one and oil leaked real bad, now i got one but my powercoated block looks like hell
luuisss
15
Oct 2, 2012 06:36 AM
Si_chRis
18
Jul 5, 2006 05:25 PM
