Puffing noise in engine
I found out what's wrong. It's an exhaust leak. Check where u bolt the headers to the front firewall. and if it's a hf header, make sure u bolt all the bolts under all the 3 pieces. Which are, HF header,HF collector,HF pipe that goes to the cat. It has 2 springs on it.! From that your problem sound be fix.!
is this like an empty can with rocks inside sound?
im having the same problem too..
pictures of the location of the problem your talking about would help us in need. and what tool to use to adjust/tighten it.
Like i said. i used the HF manifold and all the HF pipes and hook it on my ZC dohc motor. It fits. And there's 9 bolts that needs to be tighten very good so it doesn't HUFF and PUFF any air out. Exhaust leak is what's it's called.
blk2mid2sol
May 13, 2007 08:32 PM
ghettogk
Nov 15, 2004 06:38 AM
Hatch It
Apr 15, 2004 07:20 AM
