1994 Honda Accord LX Codes
Old Feb 11, 2005 | 12:10 PM
Vandalrugby's Avatar
Default 1994 Honda Accord LX Codes
I recently read an article on here about being able to jumper the ECU to get the code. My "check engine light" popped on a few days ago, so I jumpered the little blue connection below the glove box. I got 4 long flashes and One short. Would anyone happen to have the codes or a link to them so I can further troubleshoot?
Old Feb 11, 2005 | 12:24 PM
tonezilla's Avatar
Default Re: 1994 Honda Accord LX Codes (Vandalrugby)
code 41 = oxygen sensor heater
http://www.hondata.com/techecucodes.html
Old Feb 11, 2005 | 12:30 PM
Default Re: 1994 Honda Accord LX Codes (redxalien)
Hey thanks alot. I guess my second question would be where is that exactly? And how easy would it be to fix?
Old Feb 11, 2005 | 05:00 PM
tonezilla's Avatar
locate the oxygen sensor and disconnect it and connect an ohmmeter between the C & D terminals . it should measure 10 - 40 ohms .
--l``l--
l A l B l
l C l D l
and check for the voltage on the connector on the ecu harness . measure the voltage between the yellow/black wire (+) and the green/blue wire (-) . there should be battery voltage with the ignition key ON (engine not running) .
if the oxygen sensor fails any of these tests, replace it with a new part . i hope that helped you out .
crxpwr1
Aug 25, 2019 11:46 AM
backwood1
Sep 6, 2018 10:30 AM
HEEDO
Engine Management and Tuning
Sep 8, 2017 03:27 PM
dejay2014
Aug 27, 2014 06:41 PM
Yogster
May 31, 2003 11:30 AM
