****D SERIES*****TURBO KIT FOR SOHC*****220WHP*****LOTS OF PICS/DYNO SHEETS*****
Old Feb 11, 2005 | 11:09 AM
98gsrTEG's Avatar
Default ****D SERIES*****TURBO KIT FOR SOHC*****220WHP*****LOTS OF PICS/DYNO SHEETS*****
LOOKING TO GET 700.00 BUYER PAYS SHIPPING, SHIPPING WILL BE 75.00 AND BY FEDEX:-D
Below you will find LOTS of pictures, time slips, dyno pulls, and movies, and vouches... Enjoy :-D * THROW THEM OFFERS UP!!!*
Turbo & Manifold Information:
The turbo is a Garrett/Airesearch T3 turbo, off of a Saab 900, which was newly (oct. 2004) bought off a Mutual Friend on (xceedspeed.com). Turbo is immaculate, no shaft play, spins free as all hell, and leaks NO OIL. It is tapped for both oil and water (I only used oil [i heard a rumor that this turbo is a ball bearing due to the quad cooling jackets] ) The Specs are; .42 compressor, and .48 hot side. The exhaust flange is a 5 bolt pattern. Turbo is definately good for 200-275hp, and has seen steady 10psi. Spooling is almost instantanious, in a 4th gear dyno pull it fully spooled to 8 psi @ 3100RPM (see Dyno Graphs) crazy fast spool. The first dyno pull was @ 13 psi and yelided 213whp and 198 wtq and that was only till 5000 RPM!!! crazyness. All oil lines are purchased from honda-tech.com, from made in iraq. The second exhaust housing is a 4 bold flange pattern and a .63 a/r if you want to make it an even faster and efficent turbo. The downpipe was hand made and MIG welded less than a month ago, its 3 inches and a 5 bolt pattern, it has 2 o2 bungs, and i will supply a o2 sensor. The manifold is a S.S. Auto Chrome bought in Sept. 2004, it is a 2nd gen manifold, and <u>is braced</u>. Manifold has been run for over just over 4k miles and has no cracking. if you plan on using a internal wastegate with the turbo ($75.00), i will supply you with a external block off plate which will totally rule out this manifold boost spiking. ADO B.O.V was givven to me by a buddy it mounts the same as a RFL. The khumo slicks have been used for 1 season, hooks hard!
*KIT WILL FIT ALL 88-00 D SERIES *
Contents Of Sale
- All oil lines
- Extra .63 A/R exhaust housing
- Extra oil pan
- Johnny Racecar 6" intercooler
- Turbo manifold with 38mm flange
- 3" downpipe with two o2 bungs welded in
- denso o2 sensor
- all bolts for turbo mounting
- all gaskets
- Garrett Airesearch T3 turbo .42/.48
- All Sensors Needed
- ADO Blow Off Valve
- (2)Khumo victoracer 205/50/15 slicks mounted on Omni rims
<u>Down to the good stuff now! IF LINKS DO NOT OPEN CORRECTLY TRY RE_LOADING THEM TILL THEY DO, THEY WILL LOAD!!!!!!!</u>
<u>Pictures:</u>
Front intercooler shot
http://www.we-todd-did-racing.com/wetoddim...zMXk1NDE%3D.jpg
Install 1
Install 2
Install 3
Turbo
On Dyno 1
On Dyno 2
On Dyno 3
manifold
http://i21.ebayimg.com/02/i/03/60/3e/66_1_b.JPG
Close up on Turbo A/R .48
http://i20.ebayimg.com/03/i/03/60/a9/58_1_b.JPG
Group shot of turbo, oil lines and .63 exhaust housing
http://i21.ebayimg.com/01/i/03/60/3e/89_1_b.JPG
close up of .63 A/R
http://i1.ebayimg.com/03/i/03/61/f3/0b_1_b.JPG
Intercooler pic
http://i17.ebayimg.com/02/i/03/60/4d/b4_1_b.JPG
Intercooler and d/p and o2 sensor pic
http://i12.ebayimg.com/02/i/03/60/8a/ce_1_b.JPG
Khumo drag radial/ slicks pic
http://xceedspeed.com/forums/files/pizza_159.jpg
<u>Dyno Graphs:</u>
Graph 1 - Torque and AFR
Graph 2 - Vacuum/Boost pressure
Graph 3 - HP and Torque
<u>Time Slips / Milan:</u>
Milan 14.86 @ 98.0 With horrible 60 ft.Untuned.
Milan 14.89 @ 86 With horrible 60 ft. and coupling blew off at end of 3rd gear.Untuned.
Boostie pulling on yellow Trans Am at milan
<u>Movies:</u>
Dyno Pull to 5k
http://www.we-todd-did-racing.com/Hosting/...kZmQzMXk1NDE%3D
Contact Information & Vouches:
SERIOUS INQUIRYS ONLY PLEASE!
AIM: Injekushon Boost
VOUCHES can be found here -&gt; http://xceedspeed.com/forums/viewtopic.php?p=305487
Thank you!
B)
Old Feb 11, 2005 | 11:58 AM
98gsrTEG's Avatar
Default Re: ****D SERIES*****TURBO KIT FOR SOHC*****220WHP*****LOTS OF PICS/DYNO SHEETS***** (98gsrTEG)
bump
Old Feb 11, 2005 | 05:15 PM
Soccerking3000's Avatar
is the mani/turbo a/c compatible?
Old Feb 12, 2005 | 12:36 AM
98gsrTEG's Avatar
bump
Old Feb 12, 2005 | 05:11 AM
BigMig's Avatar
Default Re: (98gsrTEG)
i got a friend that is interested. PM sent
Old Feb 12, 2005 | 08:42 AM
DaFredsta's Avatar
Default Re: (BigMig)
pm sent
Old Feb 12, 2005 | 07:40 PM
98gsrTEG's Avatar
for the right price the Drag radials will be dropped... alot of people intrested, some PMs replied, most reliable way to get ahold of me is to IM me @ injekushon Boost thanks...
Old Feb 12, 2005 | 08:30 PM
RAS Motorsports's Avatar
pm sent
Old Feb 13, 2005 | 09:24 AM
98gsrTEG's Avatar
bump want this sold
Old Feb 14, 2005 | 10:10 AM
98gsrTEG's Avatar
bump
Old Feb 14, 2005 | 03:31 PM
98gsrTEG's Avatar
bump bro
Old Feb 14, 2005 | 05:56 PM
98gsrTEG's Avatar
PENDING SALE TO almo5tfa5t
Old Feb 15, 2005 | 11:16 PM
98gsrTEG's Avatar
SOLD sorry for all the other people who wanted it this was sold, the manifold is still avil. for 100.00
Old Mar 31, 2005 | 03:06 PM
Almo5tFa5t's Avatar
Hit me back.
Old Apr 1, 2005 | 12:34 PM
lojackgsr's Avatar
i am so so mad, if something doesnt work out lmk please..
Old Apr 1, 2005 | 12:46 PM
JD95hatch's Avatar
Default Re: (driftinitup)
220whp and u got a 14.9....
Old Apr 1, 2005 | 04:51 PM
Almo5tFa5t's Avatar
Default Re: (JD95hatch)
I hope it woks out, I kinda paid for it almost 2 months ago , just kinda having some problems to sort out with shipping =/
Old Apr 6, 2005 | 03:59 PM
Almo5tFa5t's Avatar
Default Re: (Almo5tFa5t)
Still waiting for a reply from 98GSRTEG....
Old Apr 9, 2005 | 05:20 PM
Almo5tFa5t's Avatar
after a almost 3 month i have my stuff... or atleast a working tracking number.
Old Apr 18, 2005 | 06:09 PM
ieatpaint315's Avatar
Must be nice...I sent money for the d16z6 he supposedly has, still haven't seen that. Good thing I don't have a car with no motor in my driveway....
Old Apr 27, 2005 | 05:59 PM
Almo5tFa5t's Avatar
Default Re: (ieatpaint315)
you just need to keep on him. it took me calling his home and talking to his mom before he got it all out to me.
acrocat
Mar 16, 2009 08:42 AM
integraboosted
Feb 12, 2007 10:47 AM
MidShipCivic
Nov 14, 2006 01:32 PM
DIRep972
Sep 29, 2004 09:06 AM
Night_Minx
Jun 24, 2002 04:36 PM
