What the heck is this!?
Old Feb 11, 2005 | 11:00 AM
DaMmniTz's Avatar
Default What the heck is this!?
What the heck is this on a ZC MOTOR? I believe it's on all honda's motor but what is it? TPS controL? ANd what wires goes there? I have a 3 wires and they are black, yellow, black. That goes into those 3 pins. But which wires go to which!?
Old Feb 11, 2005 | 11:07 AM
EL Vap133's Avatar
Default Re: What the heck is this!? (DaMmniTz)
Which one are you talking about?
Old Feb 11, 2005 | 11:09 AM
90 Si Hatch's Avatar
well i'm not to sure what they are or what they do, but last night when i took my Si motor out of my car i un-hooked those plugs and i remember where they go,......
the sensor that has 2 plugs the Yellow wire goes on the top and the Black on the other and the sensor that has 1 plug the other black wire goes on it
Old Feb 11, 2005 | 11:11 AM
thumbtack's Avatar
The one with the two prongs is the temperature sensor for the block. I don't know about the other one.
Old Feb 11, 2005 | 11:19 AM
DaMmniTz's Avatar
alright thanks. i knew i put it right, just wasnt' 110% sure.!!!
Old Feb 11, 2005 | 11:22 AM
gaydm.accord's Avatar
Default Re: What the heck is this!? (thumbtack)
temperature sensor? or oil pressure switch? i coulda sworn it was oil pressure, i could be wrong someone shed some light on us. the other is knock sensor.
Old Feb 11, 2005 | 11:25 AM
DaMmniTz's Avatar
i hope this didn't cause the motor to sound like it is.!!!
Motor video while motor is on!
http://home.ripway.com/2005-2/...5.MOV
Old Feb 11, 2005 | 11:26 AM
link no workie
Old Feb 11, 2005 | 11:32 AM
sounds liek an exhaust leak
Old Feb 11, 2005 | 11:36 AM
wrXtian's Avatar
Default Re: (gaydm.accord)
the single prong is the oil pressure i believe.. not 100%, but if you were to turbo your engine you would unhook that single prong one and set up your oil feed through it then re install it.. so i just always assumed it was oil pressure lol
Old Feb 11, 2005 | 11:40 AM
JapJunkie's Avatar
Default Re: What the heck is this!? (gaydm.accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gaydm.accord &raquo;</TD></TR><TR><TD CLASS="quote">temperature sensor? or oil pressure switch? i coulda sworn it was oil pressure, i could be wrong someone shed some light on us. the other is knock sensor.</TD></TR></TABLE>
the one w/ one nipple is the oil pressure switch.
DaMmniTz's Avatar
what the heck is an exhaust leak!? The noise is coming from the MOTOR inside i believe! I was actually thinking it was bad valves or timing was wrong. But exhaust.!!!!! dunno.
Old Feb 11, 2005 | 11:45 AM
GSRCRXsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaMmniTz &raquo;</TD></TR><TR><TD CLASS="quote">what the heck is an exhaust leak!? The noise is coming from the MOTOR inside i believe! I was actually thinking it was bad valves or timing was wrong. But exhaust.!!!!! dunno.</TD></TR></TABLE>
where do you think the exhaust comes from? inside your engine. you can have an exhaust leak at the manifold right off the engine.
Old Feb 11, 2005 | 12:32 PM
DaMmniTz's Avatar
Check my bolts already, all bolts on the manifold and headers are bolted on!!!
the engine shakes aloT!!!!!!!
Old Feb 11, 2005 | 01:03 PM
nuckingfuts's Avatar
sounds like you may have the firing order messed up..
FIRING ORDER = 1-3-4-2
looking at the engine from the front, it goes 4-3-2-1 (left to right) maybe someone will post up a pic
Modified by nuckingfuts at 10:19 PM 2/11/2005
Old Feb 11, 2005 | 01:21 PM
Default Re: What the heck is this!? (nuckingfuts)
yup this could also be the problem but then again you would get some back fire wouldnt you?
Old Feb 11, 2005 | 01:39 PM
fourthgenhatchB17's Avatar
2 nipple plug is fan switch (if u leave it unplgged, your fan wont turn on), single nipple is oil psi switch as japjunkie stated (its for the warning light on your gauge cluster).
Old Feb 11, 2005 | 02:10 PM
DaMmniTz's Avatar
The engine starts up okay but is it suppose to have a " PUFFING " noise from the engine/headers? at the same time the engine shakes also when it's puffing.
CKnight90
Nov 2, 2014 11:49 AM
horn12007
Nov 11, 2010 01:53 PM
sleep_Rx
Dec 4, 2007 01:10 PM
b16acrxer
Dec 8, 2003 04:38 PM
