Buying a set of Yokohama AVS ES100, what size would be great with GSR blades?
Old Feb 11, 2005 | 09:06 AM
XyKo
Guest
Posts: n/a
Default Buying a set of Yokohama AVS ES100, what size would be great with GSR blades?
Is the stock 195/55/15 good or should I get a wider one?
205/55/15
205/50/15
Please let me know. Ordering in 2 hours. Thanks
Old Feb 11, 2005 | 09:07 AM
wanna b R's Avatar
Default Re: Buying a set of Yokohama AVS ES100, what size would be great with GSR blades? (XyKo)
205 50 15
Old Feb 11, 2005 | 09:31 AM
redGSRguy's Avatar
I'm also running 205/50/15.
Old Feb 11, 2005 | 10:42 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Buying a set of Yokohama AVS ES100, what size would be great with GSR blades? (redGSRguy)
195/55-15 would be best if they have them in stock. They're quite a bit cheaper than 205/50 and might experience a little less sidewall rollover in corners.
I currently have 195/50-15 ES100's on my stock GS-R wheels, only because 195/55 was on backorder at the time. But I like the smaller diameter of the 195/50's, helps acceleration a little bit.
Old Feb 11, 2005 | 11:13 AM
aznballer's Avatar
i got 195 55 es100 on my bladez and it works out great
Old Feb 11, 2005 | 11:17 AM
CNSK's Avatar
Default Re: (aznballer)
i like 195/55 more....raises my car a bit tap higher....but ive run 205/50 and its good also...no wrong way..
Old Feb 11, 2005 | 12:09 PM
XyKo
Guest
Posts: n/a
Default Re: (CNSK)
How's the noise level? And how is this compares to Kumho Ecsta ASX and 712? Trying to decides which one to get.
Old Feb 11, 2005 | 12:15 PM
XyKo
Guest
Posts: n/a
Default Re: (XyKo)
Hmm might cancel out on the 205/50/15, cost $78/ea on tireracks.
So, how about 195/50/15 compares to the 195/55/15?
Old Feb 11, 2005 | 12:39 PM
Community Builder
Default Re: (XyKo)
I have heard that ES100's are quieter then Krapho 712's, but they do get fairly loud as they wear down.
Old Feb 11, 2005 | 01:46 PM
Moogen Powah's Avatar
Default Re: (PatrickGSR94)
If you want to keep your speedo accurate, go with the 195/55/15.
Also, 195/50's do not have the proper load rating, BUT, there are people who have run this size w/o any problems.
Old Feb 11, 2005 | 02:04 PM
TeaAddict's Avatar
i hate my 712s (maybe its cuz i'm on 17s)
Old Feb 11, 2005 | 02:08 PM
.water's Avatar
iam rolling on 195-55-15 really dig in those tires
Old Feb 12, 2005 | 02:08 AM
Stock_Racing's Avatar
i would go for falken 195/50/15 for some Gsr blades
Old Feb 12, 2005 | 07:15 AM
Community Builder
Default Re: Buying a set of Yokohama AVS ES100, what size would be great with GSR blades? (Beast_16A)
what sort of Falkens?
Ziex's aren't that great, and Azenis don't come in 195/50 size. 205/50 Azenis are way too wide for stock 15x6 wheels IMHO. They are much better suited for 15x7 wheels.
Old Feb 12, 2005 | 07:22 AM
black_cap's Avatar
Default Re: Buying a set of Yokohama AVS ES100, what size would be great with GSR blades? (PatrickGSR94)
I had this debate awhile back as well. I went with the 195/55. If your going for looks there isn't much of a difference. Also the price is quite a bit different in the two. Couldn't be happier with the ones I got
Old Feb 12, 2005 | 02:46 PM
Pythagoras's Avatar
I just bought a set of these a lil while ago....I got 205/50/15
Old Feb 12, 2005 | 02:58 PM
FR-MOB: ThE bEe GuY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
I currently have 195/50-15 ES100's on my stock GS-R wheels, only because 195/55 was on backorder at the time. But I like the smaller diameter of the 195/50's, helps acceleration a little bit. </TD></TR></TABLE>
I'll vouch for that 195-50's made my LS accelleration a LOT better. Yes it throws off the speedo but only by 4mph, no biggy, the stock gauges in general arent that accurate anyways
Old Feb 12, 2005 | 03:01 PM
.special ed.'s Avatar
Default Re: Buying a set of Yokohama AVS ES100, what size would be great with GSR blades? (ThE bEe GuY)
how does it help your accel?
Old Feb 12, 2005 | 03:11 PM
Default Re: Buying a set of Yokohama AVS ES100, what size would be great with GSR blades? (slow_95se)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow_95se &raquo;</TD></TR><TR><TD CLASS="quote">how does it help your accel?</TD></TR></TABLE>
Since the overall diameter of 195-50's are smaller than stock tires, it makes 1 full rotation quicker than 195-55's, so it equals a quicker accelleration at the cost of gas mileage (very minimal gas mileage difference, almost negligable unless you take long trips).
Old Feb 12, 2005 | 03:16 PM
.water's Avatar
if u want more detail piics..i will take some
btw next time iam gonna try falken 512..but righ now iam really happy with es100..in here rain too much..
Old Feb 12, 2005 | 04:32 PM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThE bEe GuY &raquo;</TD></TR><TR><TD CLASS="quote">Since the overall diameter of 195-50's are smaller than stock tires, it makes 1 full rotation quicker than 195-55's, so it equals a quicker accelleration at the cost of gas mileage (very minimal gas mileage difference, almost negligable unless you take long trips).</TD></TR></TABLE>
What you experience is an effectively higher final drive ratio due to the tire's smaller rolling diameter.
Old Feb 12, 2005 | 05:11 PM
Cliffjumper2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">what sort of Falkens?
205/50 Azenis are way too wide for stock 15x6 wheels IMHO. They are much better suited for 15x7 wheels.</TD></TR></TABLE>
I had a set of 205/50/15 azenis on a set of 99 civic si wheels on my teg; they worked well, since the azenis have a very strong sidewall (heavy too). Here's a pic of them:
Though my favorite setup was a set of 205/50/15 bridgestone potenza s03 tires on a set of 15x6.5 (40 offset) rota slipstreams
a setup I experimented once with while I had a couple set of wheels at a time, (I buy and sell wheels all the time), was 205/50/15 on the front with 195/55/15 on the rear......I liked this setup and have thought of doing it with the same set of rims, but rotating tires would not be good with this setup
Old Feb 19, 2005 | 09:12 PM
khmy2nr's Avatar
Default Re: Buying a set of Yokohama AVS ES100, what size would be great with GSR blades? (Cliffjumper2)
Old Feb 19, 2005 | 11:04 PM
hadboosttroy's Avatar
Default Re: Buying a set of Yokohama AVS ES100, what size would be great with GSR blades? (khmy2nr)
Get the 195/55 if you are on 15x6. I will never understand people who put a 205/50 azeni (which is wider than a typical 205) on a 15x6 rim. They must like it sloppy and shitty?
Old Feb 20, 2005 | 04:30 PM
Gerbilo's Avatar
Default Re: Buying a set of Yokohama AVS ES100, what size would be great with GSR blades? (hadboosttroy)
I have 195/55 ES100s on my stock blades, probably the size i'm going to stick with for my next set. They are far superior to the Ziex's i had on my civic, just letting you know.
