CRV-99...Turn Radius Noise
Old Feb 11, 2005 | 08:15 AM
lmccammon's Avatar
Default CRV-99...Turn Radius Noise
New to the forum---> I have a concern about my 1999 CRV.
Whenever I make a tight turn(u-turn, parking, etc) I get this muffled squealing noise. It also gives off a little bit of vibration. Sounds like rubbing, yet it's not. I thought it might have to do with the power steering fluid- checked it, it's good. I also wonder if it may be a joint problem, yet I'm not picking up any 'metal', clicking, or grinding noise.
Any ideas? What's the most common problem? And if someone is familiar, is it an easy fix- or does it require a trip to the dealer? Thanks for any assistance
Old Feb 11, 2005 | 01:04 PM
Tstorm's Avatar
Default Re: CRV-99...Turn Radius Noise (lmccammon)
Try changing the rear diff fluid, if 4wd. Honda dual pump fluid.
Old Feb 16, 2005 | 07:16 AM
lmccammon's Avatar
Default Re: CRV-99...Turn Radius Noise (Tstorm)
Thank you!
Old Feb 16, 2005 | 03:52 PM
EG1.8cT68's Avatar
You should change the fluid every 30k, it only requires 1 quart of DUAL PUMP fluid, which you can get at your local dealer. But remember you can only use the DP fluid from honda because it is a certain blend made specifically for you diff for Honda.
transitions
Honda CR-V & Element
Nov 16, 2010 12:22 PM
questseek
Mar 6, 2010 09:32 PM
superwell
Sep 27, 2009 12:41 AM
D.WERKZ
Apr 5, 2008 05:40 PM
Silvteg95
Aug 4, 2005 05:01 PM
