GSR on EG....
Old Feb 11, 2005 | 08:13 AM
POWERINTEGRA's Avatar
Default GSR on EG....
I was wondering what is best for brake set up!
swap GSR parts into the eg complete brakes/ suspension?
or would it be better to get aftermarket parts
like skunk coil overs
teins etc...
This will be a dayli driven/track car
what are you guys using?
I want to keep it 4 lug
Old Feb 11, 2005 | 08:36 AM
EG_Platano's Avatar
Default Re: GSR on EG.... (POWERINTEGRA)
you should hit up the search button
Old Feb 11, 2005 | 11:09 AM
one8toh8's Avatar
Default Re: GSR on EG.... (92EGJDMB16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92EGJDMB16 &raquo;</TD></TR><TR><TD CLASS="quote">you should hit up the search button</TD></TR></TABLE>
dude chill with the search button ****, i believe he knows how to search. he asked a queastion and if you don't have the answer or anything to add to it don't put comments like that, expecailly since you a noob.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by POWERINTEGRA &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering what is best for brake set up!
teins etc...
I want to keep it 4 lug </TD></TR></TABLE>
yo i say you do what ever you want I mean if you are going to swap all that just swap the gsr brake components and then up grade the stock suspension with like kyb(agx) shocks and skunk 2 coilovers. thats what im doing soon.
Old Feb 11, 2005 | 02:46 PM
A.E Motoring's Avatar
well me personally i would upgrade all the brakes to gsr front, rear...and then get some aftermarket suspension...but then if your just going to keep it stock hight then switch over the suspension as well
Old Feb 11, 2005 | 02:49 PM
SkRiBLaH's Avatar
******* 5 posts and already bitchen about the search
Old Feb 11, 2005 | 02:50 PM
.BigSexy's Avatar
most hood white kid
Default Re: GSR on EG.... (one8toh8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by one8toh8 &raquo;</TD></TR><TR><TD CLASS="quote">
yo i say you do what ever you want I mean if you are going to swap all that just swap the gsr brake components and then up grade the stock suspension with like kyb(agx) shocks and skunk 2 coilovers. thats what im doing soon. </TD></TR></TABLE>
I hear skunk 2 coilovers aren't all that hot. And if I were to go coilovers, I would buy a complete system sort of like the omnipower coilovers, rather than buy struts and then coils. If I were this guy, I would upgrade suspension all the way, kyb struts are nice, then maybe some neuspeed or eibach sportlines, there are so many options out there it is unreal, but it is up to you to decid. But I say go with after market suspension
Old Feb 11, 2005 | 02:51 PM
.BigSexy's Avatar
most hood white kid
Default Re: GSR on EG.... (SkRiBLaH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkRiBLaH &raquo;</TD></TR><TR><TD CLASS="quote">
******* 5 posts and already bitchen about the search</TD></TR></TABLE>
tell us about it!
Old Feb 11, 2005 | 03:52 PM
KRaZee_TiNy's Avatar
well, i have did a gsr swap into a eg n changing up the rotors and brake line and dot5 fluid, and to my knowledge it also best to change up the master cylinder and brake booster because the better pressure to your braking the less it locks on you. I did a test and it really help a lil bit so my recommendation is to change up the mc and brake booster to a teg and you will get a better braking. If you think of doing ABS, its more effort but then you have to change axles with the sensor.
Old Feb 11, 2005 | 06:20 PM
I understand you need a couple of posts before you are no-more a trial member.
But if you keep posting **** like this you will get no where...
Now to the other stuff:
Yeah guys I see alot of people using the GSR stuff and I wanted to know how is working for you guys out there, becasue I was thinking of doing the same and use some aftermarket shocks and coil overs. But since is the 1st time I'm doing this I wanted to get some input as far as how the car rides etc...
and thanks for all the recommendations from all of you
Old Feb 11, 2005 | 06:24 PM
CHiNkStEr's Avatar
forget gsr brakes. get 5 lug so you can brake like crazy!
Old Feb 11, 2005 | 07:07 PM
albert's Avatar
I love my gsr brakes on my eg hatch stops hella fast
Old Feb 11, 2005 | 08:37 PM
Ajax's Avatar
Default Re: (*****StEr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by *****StEr &raquo;</TD></TR><TR><TD CLASS="quote">forget gsr brakes. get 5 lug so you can brake like crazy!</TD></TR></TABLE>
I hope thats a joke. I really doubt the 5th lug has anything to do with your stopping ability.
Old Feb 11, 2005 | 10:04 PM
litterbox's Avatar
I am a (Trial User) Army
Default Re: (Ajax)
https://honda-tech.com/zerothread?id=1036267
Courtesy of 94eg!
Old Feb 12, 2005 | 01:45 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Default Re: (Ajax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ajax &raquo;</TD></TR><TR><TD CLASS="quote">
I hope thats a joke. I really doubt the 5th lug has anything to do with your stopping ability.</TD></TR></TABLE>
Why? It's ITR rotors and brakes to go along with that extra lug.
Old Feb 12, 2005 | 08:10 PM
Default Re: GSR on EG.... (KRaZee_TiNy)
Sorry to PowerIntegra
Modified by KRaZee_TiNy at 8:16 AM 2/13/2005
Old Feb 12, 2005 | 08:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KRaZee_TiNy &raquo;</TD></TR><TR><TD CLASS="quote">to mr powerintegra, meaning what posting **** like this will get nowhere. i probably don't post alot because **** like this not worth of trying so help, but i can tell you this, i been throught alot of swaping, installing, testing, then you. i really don't take such comment easily, i get very offended when helping people and that is the reason y my name still a trail user. number doesn't count buddy only knowledge.</TD></TR></TABLE>
what?
weird
I don't understand
Old Feb 12, 2005 | 08:16 PM
TeamNextGenChris's Avatar
there is a ton of info on brakes/suspension to be found by searching.
the GSR brakes are a good upgrade.get some new rotors and good pads and they'll work very well.
the swaybars will help,although you may want to go a little bigger on the rear bar.if you're learning,the stock GSR rear bar will work very well though.
if you'll be tracking the car,you definitely want upgraded shocks and springs.full coilovers are a waste of mony IMO unless you are a good enough driver to actually use their tune-ability and performance on the track.a beginner isn't,and neither are 90% of experienced drivers.some good coilovers(Ground Control)and adjustable shocks(Tokico,Koni,AGX-whatever your preference)will give you more performance than you'll be able to use.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I hear skunk 2 coilovers aren't all that hot</TD></TR></TABLE>
they're okay.i've had them on my coupe for about six or seven years now with no problems.the sleeves have held up fine,but i know(or at least they used to,don't know about now)they use no-name springs which could possibly have a lot of variance and may not hold up well.i can't tell any change in my car,but I'm sure it'd be so gradual i'd never notice anyway.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">what?
weird
I don't understand
that's what i said.WTF is he talking about?!
Chris
Old Feb 12, 2005 | 11:15 PM
My bad, i thought that meant for me. I apologize for that. I miss look at your quote to that other guy.
Old Feb 13, 2005 | 12:27 AM
JDMGSR EG's Avatar
krazee tiny just needs to watch the posts better
Old Feb 13, 2005 | 03:44 PM
CHiNkStEr's Avatar
Default Re: (Ajax)
i meant itr 5 lug conversion bro. obviously you've never drive a car wit a itr 5 lug conversion before because it does give you more stopping ability.
civic eg k20
12
Nov 7, 2007 05:27 PM
civicb18Tkid
39
Jul 26, 2007 11:38 AM
JDM 93 EJ1
Nov 20, 2004 03:53 AM
S@nt0s
Jan 16, 2004 06:24 AM
sirIIking
Oct 7, 2003 02:00 PM
