tie rod/ball joint question
Old Feb 11, 2005 | 07:57 AM
PrinceAli132's Avatar
Default tie rod/ball joint question
I'm trying to figure out whats wrong with my car. Well it feels like my steering is loose, more so when i turn the wheel right. The steering feels unresponsive. I've been searching, trying to figure out whats wrong, and the only thing i can think of is either the ball joint, or innner/outer tie rods. Basically, what i'm asking is if anyone knows of any ways that can help me determine/diagnose my problem. And if it helps, this is on a 98 LS with ground control coilovers, and koni yellows, with the skunk2 camber kit. Any help would be appreciated. TIA
Ali
Modified by PrinceAli132 at 4:40 PM 2/11/2005
Old Feb 12, 2005 | 03:24 PM
Default Re: tie rod/ball joint question (PrinceAli132)
Anyone?
Old May 12, 2009 | 07:04 AM
fanny's Avatar
New User
i need to kno if i will require a torch to replace a inner tie rid on a 93 civic.im trying to replace in my driveway.does anyboddy think this is a no no?????
Old May 12, 2009 | 09:12 AM
Berlinetta F1's Avatar
jack the car up and see if anything looks worn, broken, or loose
i wouldnt drive the car untill you find out whats wrong. if one of your ball joints is about to come appart then it needs to be fixed right away. if it comes all the way out your car will just drop the the ground and all hell will break loose.
DA nightmare
Jan 19, 2014 03:57 PM
Atomic1
Sep 19, 2011 01:42 PM
civicdelsol33
Aug 16, 2007 09:18 PM
theemaddhatterr
Dec 29, 2005 02:54 PM
