95 dashboard into a 99?
I bought my 99 LS with a tan interiour, and I wanted to put a black leather GS-R interiour in instead. I've got a black dashboard from a 1995. I know this will fit... but what about the wiring harnesses? Will I have to do any swapping of parts in that regard?
think of the dash as a car.. you can but them as a shell or with things included. this is like a shell so you put your harnesses and clips to their right location and youre good to go
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aracheon »</TD></TR><TR><TD CLASS="quote">Will I have to do any swapping of parts in that regard?</TD></TR></TABLE>
no.
no.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 »</TD></TR><TR><TD CLASS="quote">
no.</TD></TR></TABLE>
correct
correct
Here:
https://honda-tech.com/zerothread?id=954173
we had a black dash out of a 99 gsr (so we were told), and every plug went in just fine to the 94 plugs that were part of the dash wiring harness. a couple plugs were cut off the 99 black dash cause it had indiglos or something, and was poorly done...so we had to rewire a plug to certain wires.
also the main dash wiring harness stays in the dash frame when you take the dashboard off so I'm 99% sure you shouldn't have any problems with the 1 percent being the srs harnesses but that's only if you are using the airbags off the 95 dasha nd steering wheel and not reusing your 99 ones.
courterman08
11
Sep 20, 2007 12:26 PM
whole9
Northwest (Sales)
19
Jan 23, 2006 12:11 AM
