Generic Mechanic Contract for Swap - Opinions Needed
Hi Guys.
After reading the advice on the Honda-TECH sticky I want to make some sort of contract before I hand over my car to the mechanic to fix it...worse still he will do a backyard Tax free Job
So i want to write a generic contract which u people can ammend and add to and then eventualy maybe we can sticky it
So heres my first Draft
Its a H23a to a H22a swap in a Prelude Si)
TO WHOM IT MAY CONCERN
I ___________________ , Licence No: _______________am agreeing to perform the following services on Honda Prelude (Rego No# __________ ) owned by Mr. _________________________. The services I will perform will include parts and labour and is quoted to be ________$
I will perform the following services and will warranty the work for ___ months :
1. Swap the Honda Prelude H23a Engine/Radiator with the following H22a Engine/Radiator with VIN No. # ______________
2. Change Clutch (Exedy Clutch) [Supplied by Customer]
3. Change Timing Belt [Supplied by Customer]
4. Change Water Pump (GMB OEM Japan) [Supplied by Customer]
5. Perform a Conversion from the H22a automatic Timing Belt Tensioner to H23a1 Manual tensioner [Parts Supplied by Customer ]
6. Machine Front Hubs to stop Vibration under Load.
7. Change Front Brakes.
While the Car is under my possession I hold all responsibility and liability for the Car and its contents
Mechanic providing Services: Owner of Car :
__________________________ ________________________
Modified by OzWolfbane at 8:04 AM 2/11/2005
Its a H23a to a H22a swap in a Prelude Si)TO WHOM IT MAY CONCERN
its not a trust issue , but if u read the sticky about doing major work on the car it says to get everything in writing, coz a mechacnic is ur best friend until something goes wrong. !!!!
Hmm terms of condition breaches....i wont scare the guy with those
I think it looks good eh ?
All the sticky means is that you should have the mechanic write/print a work order with an estimate in it. Not that you should write your own contract. And I agree with dmx if you dont trust him enough to have him sign a contract then why trust him with your car?
superturboprelude
Sep 29, 2004 08:28 PM
