Buddy Club Spec3+ valve lash???
Old Feb 11, 2005 | 02:41 AM
Yusuke's Avatar
Default Buddy Club Spec3+ valve lash???
I'm having trouble with the valve lash that Buddy Club recommends for their Spec3+ cams. Yesterday I had to adjust my valve lash to 11 intake 13 exhaust because my engine would stutter and almost die.
BC recommends 7 for the intake and 8 for the exhaust. I know there are a lot of BC3+ owners here so let's hear what your valve lash settings for these cams are.
Old Feb 11, 2005 | 06:50 AM
faSHOwidIT's Avatar
Did it run better with the 11in/13ex or was the difference only idle? I'd like to know as well.
Old Feb 11, 2005 | 06:51 AM
MethodMotorWorks's Avatar
Default Re: Buddy Club Spec3+ valve lash??? (Yusuke)
7 on intake and 8 on exhaust, thats what i do on ever cam set.
Old Feb 11, 2005 | 07:06 AM
ITRacer121's Avatar
7 and 8 is all I do too
tunning fixes the idle problem
Old Feb 11, 2005 | 08:03 AM
faSHOwidIT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yusuke &raquo;</TD></TR><TR><TD CLASS="quote">I'm having trouble with the valve lash that Buddy Club recommends for their Spec3+ cams. Yesterday I had to adjust my valve lash to 11 intake 13 exhaust because my engine would stutter and almost die.
BC recommends 7 for the intake and 8 for the exhaust. I know there are a lot of BC3+ owners here so let's hear what your valve lash settings for these cams are.</TD></TR></TABLE> You have a stock ECU?
Old Feb 11, 2005 | 08:04 AM
Yusuke's Avatar
Default Re: (ITRacer121)
The engine does run better but I don't understand why 7,8 didn't work for me. I remember reading that when BC released their Spec3's they had the valve lash set at 11,13 and when they released the Spec3+'s they recommended 7,8.
Old Feb 11, 2005 | 08:05 AM
Yusuke's Avatar
Default Re: (Yusuke)
I have a P08 with a Mugen chip. I've tried different chips but the idle always remains the same.
Old Feb 11, 2005 | 08:34 AM
MysteryWagon's Avatar
7 and 8 here, car runs and idels great. NO tuning and nothing to tune with. YOu need to set them bad boys back and tune it if you have a way.
Old Feb 11, 2005 | 09:15 AM
faSHOwidIT's Avatar
Maybe the spark timing? Stock motor or what?
Old Feb 12, 2005 | 01:00 AM
vti444's Avatar
i had set fitted in my b16a last week and exact same bad idling probs. shop said they set valve lash to 7 and 8. had apexi power fc fitted since which has sorted most of the problem out
Old Feb 12, 2005 | 02:28 AM
-=Zeqs=-'s Avatar
Default Re: (vti444)
7 & 8 lash, with a JDM P73 ECU. Runs swell.
Old Feb 13, 2005 | 12:47 AM
UNKNOWN_MEMBER's Avatar
wtf? my spec sheet said 8in 9ex.
Old Feb 13, 2005 | 02:13 AM
vti444's Avatar
Default Re: (UNKNOWN_MEMBER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNKNOWN_MEMBER &raquo;</TD></TR><TR><TD CLASS="quote">wtf? my spec sheet said 8in 9ex.</TD></TR></TABLE>
are yours fitted with them specs ? if so hows it idle ? lookin round here and few pm's i got i was told sheets are wrong and should be set to stock 7 and 8
pm'd buddyclub and emailed them few weeks back but no reply
Old Feb 13, 2005 | 07:34 AM
HondaRcB's Avatar
I'm running 8in/9ex per the spec sheet with no problems.
Old Feb 13, 2005 | 09:07 AM
tom_l's Avatar
Default Re: (HondaRcB)
hmmm. i called them 2 weeks ago and they said 8 and 9. so which is it?
Old Feb 13, 2005 | 09:15 AM
idles like stock. just hear a lil valve ticking.
Old Feb 14, 2005 | 03:01 AM
Yusuke's Avatar
I used to have my engine idle like stock. Then I changed my stock cam gears for a set of BC gears. From that point forward idle has sucked. I know what you're all thinking "The engine is way off on timing". That's what I thought at first. So we took off the plastic cover for the timing belt and set the crankshaft pulley mark with the mark that is directly on the oil pump. Assembled everything back together and the idle just won't settle. It sounds almost exaclty like a rotary engine
BRA BRA BRA BRBRBR BRA BRA BRA... and on.
Most of my friends love how it sounds but I just want a close to stock idle, not something that sounds like a drag only car. Thanks for the help.
Old Feb 14, 2005 | 06:11 AM
vti444's Avatar
keep me updated how it goes as mine is still little rougher than id like
Old Feb 14, 2005 | 07:34 AM
-=Zeqs=-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yusuke &raquo;</TD></TR><TR><TD CLASS="quote">Then I changed my stock cam gears for a set of BC gears. From that point forward idle has sucked. I know what you're all thinking "The engine is way off on timing".</TD></TR></TABLE>
ohhhhh ****...you guys notice that the BC cam gears DO NOT have the "up" marks? Hahahaha...well shiat...reset your engine timing again. Make sure the crank position is back to "up". Compare the BC cam gears to the stockers, mark the BC cam gears so they match the stockers as to the up marks. Put everything back on and make sure the timing belt tension is decent. Then...set the INTAKE side's cam timing to +2 advance. Apparently BC screwed up the slotting just a little when they designed those bastards, that's why everyone seems to have such great results with their intake cam timing advanced by 2 degrees. Good luck to you.
Old Feb 14, 2005 | 11:10 AM
vti444's Avatar
i just got reply from buddyclub usa for valve lash specs
"On the inlet is .008 and on the exhaust is .009."
gonna get mine reset top these as set at 7 and 8 at the moment
as for timing guy that fitted mine said he hard time cos he's never used toda gears before. dont know if he was useless or markings are funny on toda gears ?
can havin wrong valve lash be cause of bad idling ?
Modified by vti444 at 8:53 PM 2/14/2005
Old Feb 15, 2005 | 02:45 AM
Yusuke's Avatar
Whe I installed the BC gears I noticed that they don't have any marks... ANYWHERE. So I took one of the stock ones and aligned them both and then made my own marks. I'll have to double check to see if I didn't screw up
At least I'm not the only one with the bad idle on these cams. Thanks for all the input people. Keep it coming.
wagon-r
Jun 11, 2013 09:32 AM
mhewitt
Sep 16, 2010 10:51 AM
Footwork
12
Jun 14, 2003 01:41 AM
