What are some good cam gears?
Old Feb 11, 2005 | 01:52 AM
JDMlyfestyle's Avatar
Default What are some good cam gears?
Ive read everywhere people saying so and so's cam gears timing marks are not right. and some of them use 3 allen head screws to adjust.
Im looking for a Accurate timing and like a 5 bolt design that doesnt use allen heads id like for something to be like a 12 point or 6 point head. Something that will not slip. my AEM cam gears like to move alot. about every 2 weeks i got to re adjust them and retorqe them.
Old Feb 11, 2005 | 02:05 AM
b1ackc1v1c's Avatar
Default Re: What are some good cam gears? (JDMlyfestyle)
Never used them, but you get what you pay for imo especially when it's a SPOON product http://www.inlinefour.com/spooncamspro.html
Some extra ones http://www.inlinefour.com/adcamgear.html
Old Feb 11, 2005 | 06:10 AM
boostedcivicsir's Avatar
Mr. Badwrench
i like the spoons. easy to read and 4 bolts.
Old Feb 11, 2005 | 06:38 AM
nub.96ek's Avatar
Default Re: What are some good cam gears? (boostedcivicsir)
I've heard good things about buddy club cg's and they're super cheap... get 'em at JHPUSA.com
Old Feb 11, 2005 | 06:57 AM
evilboituan's Avatar
yeah but im gonna go with toda for performance but its gonna cost a little bit more.
Old Feb 11, 2005 | 06:58 AM
monicle's Avatar
I like my skunk2s never have them loosening (still check though). what do you have agains allen bolts?
Old Feb 11, 2005 | 06:59 AM
SlowReaction's Avatar
Default Re: What are some good cam gears? (nub.96ek)
I like the St Corsa Gears. Accurate timing marks and locking bolt.
Old Feb 11, 2005 | 12:03 PM
because i just dont feel secure with little puny allen bolts a nice 10mm bolt would make me feel better and 1 of my allen bolts is starting to strip out already and thats just from retorqing them
Old Feb 11, 2005 | 12:04 PM
POE's Avatar
POE
Default Re: (JDMlyfestyle)
skunk 2 for me
Old Feb 11, 2005 | 12:13 PM
Archidictus's Avatar
Unceasing Measure
Default Re: What are some good cam gears? (SlowReaction)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowReaction &raquo;</TD></TR><TR><TD CLASS="quote">I like the St Corsa Gears. Accurate timing marks and locking bolt.
Those are hot.
Old Feb 11, 2005 | 12:17 PM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">because i just dont feel secure with little puny allen bolts a nice 10mm bolt would make me feel better and 1 of my allen bolts is starting to strip out already and thats just from retorqing them </TD></TR></TABLE>
well, those are 6x1mm thread. they should be torqued to no more then 10 lbs/ft, easily attainable with the correct allen head on socket. i have been running the todas for 5 years with ZERO problems.
Old Feb 11, 2005 | 12:22 PM
Honda97's Avatar
Default Re: (v-tech rodney)
search
Old Feb 11, 2005 | 12:38 PM
monicle's Avatar
sounds like youre either torquing them down too tightly or using the wrong allen wrench
Old Feb 11, 2005 | 12:44 PM
Nope im torqing them correctly. with the right size allen. torqing to 8 ft lbs as i was told from AEM.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda97 &raquo;</TD></TR><TR><TD CLASS="quote">search </TD></TR></TABLE>
STFU. Ive been here way longer than you have son. i know to search. Im asking for new products that are out that are good and reliable. Dont down talk me i know what the **** im doing here. ur post is usless in here. your just making dumb senseless comments with no intentions to help. ur just trying to get that little post count up.
Old Feb 11, 2005 | 01:05 PM
skip.two's Avatar
haha one of those said '04 members.
well, i heard good things about Skunk2 and Toda camgears, but never had a chance to try them. i'm broke
Old Feb 11, 2005 | 01:12 PM
beaterdriver's Avatar
i had the skunk2's and the st corsa's.
both worked great, i just got the st corsa's b/c of the locking bolt, it made me feel a little bit more secure about not slipping
Old Feb 11, 2005 | 01:35 PM
vtec69's Avatar
I used to have toda cam gears
They wear very sturdy and more than three bolts which is always a good thing
They also only advanced and retarded 5 degrees which was the main reason why i go them because if for some reason they would have slipped they would have only moved 5 degrees instead of 10 like most other cam gears
Old Feb 11, 2005 | 01:48 PM
Honda97's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">Nope im torqing them correctly. with the right size allen. torqing to 8 ft lbs as i was told from AEM.
STFU. Ive been here way longer than you have son. i know to search. Im asking for new products that are out that are good and reliable. Dont down talk me i know what the **** im doing here. ur post is usless in here. your just making dumb senseless comments with no intentions to help. ur just trying to get that little post count up.</TD></TR></TABLE>
**** you ********, im makin fun of all the ******* that say it, cause i know you are one of them bitch. and i dont "bump" or do stupid posts to get my **** up you faggit, wer u located bitch ima run wit u and make ur ****** civic cry. HOE
Old Feb 11, 2005 | 01:55 PM
yes i am one of those people who say search. but thats on a topic that has been covered 100's of times. i havent seen this topic beatin to death.
Come find me im in Indiana. and id be glad to Own you and your car.
Old Feb 11, 2005 | 01:57 PM
Honda97's Avatar
ahahha go for it, ill spank u wit my DA **** civic hoe
Old Feb 11, 2005 | 01:58 PM
Honda97's Avatar
Default Re: (Honda97)
nice writeup on da engine clean up foo. too bad ima use it on my DA
SpoonSleeper's Avatar
I like the STR ones. Im running AEM ones right now,they get the job done
Old Feb 11, 2005 | 02:03 PM
Luserkid's Avatar
uh oh.... this thread looks like its going to go under soon.
Anyway i have a pair of A.P.e 6 bolt adjustible cam gears. I never put them on but does anyone know if there any good or not? I plan on putting them on when i get a thicker head gasket but if there not good for boost then ill switch to something else.
Old Feb 12, 2005 | 10:23 AM
jdmcx's Avatar
i have some skunk2 cam gears for sale and i am local if you are interested and if you are concerned with teh allen head bolts they can be replaced with either a 6 or 12 poing head i did that on another car which was haveing the same problem with his aem ones stripping just find the thread size and length from there
the skunk one have never sliped on me once just getting rid of them cause i need money for a new build i will probably buy them again
jason
Old Feb 13, 2005 | 06:53 PM
BauleyCivic's Avatar
Risky Business
**** you ********, im makin fun of all the ******* that say it, cause i know you are one of them bitch. and i dont "bump" or do stupid posts to get my **** up you faggit, wer u located bitch ima run wit u and make ur ****** civic cry. HOE</TD></TR></TABLE>
This is your warning.
OnePointFive
Jan 16, 2008 07:19 AM
LvN
Sep 26, 2006 08:02 PM
calvinPGMFI
Feb 24, 2006 04:38 AM
IIVIIoOkY
Feb 4, 2006 10:19 PM
the_eyecon
Apr 25, 2004 06:05 PM
