auto to manual swap?
Old Feb 10, 2005 | 09:38 PM
XpLiZiT's Avatar
Default auto to manual swap?
is it really worth it? and if anyone here has done it what kind of tranny do u suggest using?
Old Feb 10, 2005 | 09:41 PM
Luserkid's Avatar
Default Re: auto to manual swap? (XpLiZiT)
Is it worth it for you? Do you know how to drive stick? Do you want to know how to drive stick?
All on you. And get the same tranny you have just manual.
Old Feb 10, 2005 | 10:37 PM
hondatheart's Avatar
Default Re: auto to manual swap? (Luserkid)
Get the same tranny but manual. if its worth it all depends on what you plan do with it? you gonna race it? or you just want stick? or is it gonna become a project? me personally I just buy stick off the bat.
Old Feb 10, 2005 | 11:02 PM
Honda-Tech Balla's Avatar
Team Purple
Default Re: auto to manual swap? (hondatheart)
Just sell your auto and get a manual, simple as that. Manuals are generally cheaper anyway....
Old Feb 10, 2005 | 11:23 PM
KillBot's Avatar
I did it. I needed more hands-on experence. Yes it prolly cost more than just buying another car, but I learned lots...almost more than doing a motor swap.
I went with a 96 civic ex tranny for the ratios and the steel shift forks...the funny thing is, it matches my engine (y8 eng-y8 tranny) like everyone says to do.
Why does he need to get the same tranny?
Old Feb 11, 2005 | 06:07 AM
coupe99vtec's Avatar
im also planning on getting my 02 LX converted to manual, running through too much sh... i mean poo right now with prices and stuff.
Old Feb 11, 2005 | 06:44 AM
Electron_LS-Vtec's Avatar
it is worth it.... but please try to search before you ask queations again
Old Feb 11, 2005 | 07:43 AM
n2oef's Avatar
i did one in my 96 civic using a d16z6 trans but i had to rig up the pass side trans mount-any ideas on the "correct"mount and where to get one?will a 96+ manual mount work on the z6 trans?btw- i used 93 pedals with no problem!!!
Old Feb 11, 2005 | 08:02 AM
Rainman13's Avatar
From: Buffalo / St. Paul / and on weekends Plainview, MN
Default Re: auto to manual swap? (n2oef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KillBot &raquo;</TD></TR><TR><TD CLASS="quote">I did it. I needed more hands-on experence. Yes it prolly cost more than just buying another car, but I learned lots...almost more than doing a motor swap.</TD></TR></TABLE>
Me too. only when i did my conversion i had alot of friends with spare parts around so it only cost me like 200 bucks, but,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Is it worth it for you? Do you know how to drive stick? Do you want to know how to drive stick?
All on you. And get the same tranny you have just manual. </TD></TR></TABLE>
Old Feb 11, 2005 | 04:19 PM
KillBot's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n2oef &raquo;</TD></TR><TR><TD CLASS="quote">i did one in my 96 civic using a d16z6 trans but i had to rig up the pass side trans mount-any ideas on the "correct"mount and where to get one?will a 96+ manual mount work on the z6 trans?btw- i used 93 pedals with no problem!!!</TD></TR></TABLE>
If you were closer, I would take off my hasport conversion mount to see if it fit your car.
Old Feb 11, 2005 | 06:52 PM
EKvTach's Avatar
Default Re: auto to manual swap? (KillBot)
It was worth it for me, i got the car for only 1000 and spent the rest on new motor and tranny
Old Feb 11, 2005 | 08:10 PM
sinister2c's Avatar
Default Re: auto to manual swap? (EKvTach)
I think you can buy the factory Manual Mount and perch and bolt it to the frame. On the 96+ Civics, they changed the mounting so all you need to do is swap the mount and bolt on perch. The only cars and years you need a special mount is 92-95 Civics and 94+ Integras.
To my knowledge the mounting point on the tranny is the same for all D series and B-series trannies.
Old Feb 11, 2005 | 10:26 PM
Br1anPham's Avatar
Default Re: auto to manual swap? (sinister2c)
Its never worth in IMO. Sell yorur automatic, use that money to buy a stick. Might make profit instead of paying to change it.
Old Feb 11, 2005 | 10:32 PM
menkio's Avatar
Default Re: auto to manual swap? (Br1anPham)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Br1anPham &raquo;</TD></TR><TR><TD CLASS="quote">Its never worth in IMO. Sell yorur automatic, use that money to buy a stick. Might make profit instead of paying to change it.</TD></TR></TABLE>
it's realllly easy to do a auto/manual swap.. and def worth it.
Old Feb 12, 2005 | 12:41 AM
aequitas's Avatar
Br1an you talk about maybe making some money off of converting from auto to stick. i no its relatively easy but i was always under the imperssion that it would cost at least $700.
Old Feb 12, 2005 | 03:13 AM
AzntaggeR's Avatar
TSPeed Factory
place racing makes an AT to MT moutn conversion.
Old Feb 12, 2005 | 08:07 AM
KillBot's Avatar
HAsport makes a better one....
Old Feb 12, 2005 | 06:14 PM
98HB's Avatar
Default Re: (KillBot)
What about the back-up light switch thats on top of the trans, Does the auto wire harness have this plug.
Old Feb 12, 2005 | 11:19 PM
sinister2c's Avatar
Default Re: (98HB)
There is a plug that you unplug from the auto tranny...Lock Up Solenoid. It plugs directly into the reverse switch on the Manual Tranny. Trace these two wires back to the auto plug at the ECU (green and yellow wires).
Use a circuit tester to make sure its the right wires. now cut the wires at the ECU and run those two wires into the AUTO harness by the shifter.
You will need to jump the PARK switch and Connect the Neutral safety to the clutch if you want.
Here is the diagram.
Old Feb 13, 2005 | 12:27 AM
Br1anPham's Avatar
Default Re: auto to manual swap? (menkio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by menkio &raquo;</TD></TR><TR><TD CLASS="quote">
it's realllly easy to do a auto/manual swap.. and def worth it. </TD></TR></TABLE>
Im doing one for a customer right now:
the Hasport mount ran 150.
Clutch lines and pedals ran 100.
A b16 tranny is 400+/-
Shiftlinkage 100.
Axels and half shaft 100.
Starter 50.
Many would probably go get a new clutch, resurface flywheel, pilot bearing/ throwout bearing; but for arguements sake, lets say you didn't.
Thats still $900 to convert it to a manuel. What the heck... Automatics are worth more then manuels on the market; why spend money to make it worth less?
Old Feb 13, 2005 | 12:28 AM
Br1anPham's Avatar
Default Re: auto to manual swap? (aequitas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aequitas &raquo;</TD></TR><TR><TD CLASS="quote">Br1an you talk about maybe making some money off of converting from auto to stick. i no its relatively easy but i was always under the imperssion that it would cost at least $700.</TD></TR></TABLE>
I don't think you quite understood what I said.
You can make money if you sell your automatic and buy a manuel instead of converting it.
Old Feb 13, 2005 | 05:01 AM
98HB's Avatar
Default Re: (sinister2c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sinister2c &raquo;</TD></TR><TR><TD CLASS="quote">There is a plug that you unplug from the auto tranny...Lock Up Solenoid. It plugs directly into the reverse switch on the Manual Tranny. Trace these two wires back to the auto plug at the ECU (green and yellow wires).
What if you are using the auto harness in a manual car(car is already manual from factory)
Old Feb 14, 2005 | 03:19 AM
98HB's Avatar
Default Re: (98HB)
BUMP
Old Feb 14, 2005 | 05:58 AM
XpLiZiT's Avatar
Default Re: (98HB)
just one last question... does the resale value of the car drop at all from actually doing this conversion?
Old Feb 14, 2005 | 06:35 AM
KillBot's Avatar
Because I like driving a manual and I don't care about the resale value of my honda. Even when I buy another car, I'll prolly keep the one I have now.
