B18a swap into my 93 del sol. about mounts...
Old Feb 10, 2005 | 08:20 PM
solsi2000's Avatar
Default B18a swap into my 93 del sol. about mounts...
hey guys i got a good deal on a b18a and a hyrdo tranny for 600 bucks and I want to drop it into my del sol. anyways i have a d16z6 in it and i believe it is cable. So do i need the hasport cable to hyrdro conversion mount or mounts? what exactly does it do? also is it a pain in the *** to convert one another? oh yeah and can i just get and ls map and burn it to my p28 ecu?? let me know thanks, mike
Old Feb 10, 2005 | 08:25 PM
Del Sol SiR's Avatar
you have a cable tranny in a Del Sol ? If its a stock Si, which it sounds it might be, it should have hydro...
Old Feb 10, 2005 | 08:36 PM
solsi2000's Avatar
Default Re: (DelSolSiR)
its a 93 si which has the d16z6. the 94 and up have the b16a's if thats what your thinking. so is it hydro??
Old Feb 10, 2005 | 09:18 PM
Default Re: (solsi2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solsi2000 &raquo;</TD></TR><TR><TD CLASS="quote">its a 93 si which has the d16z6. the 94 and up have the b16a's if thats what your thinking. so is it hydro??</TD></TR></TABLE>
Yes it is Hydro not cable. All Del Sols are hydro unless you did some kind of janky motor swap.
Old Feb 10, 2005 | 09:21 PM
solsi2000's Avatar
thanks man i guess it is hydro. now should I just use a b18a ecu or should i burn a b18a map on my p28 ecu?
hontard
May 28, 2011 06:50 PM
D15b Sol
11
Jun 27, 2009 01:37 PM
DTK
Jul 24, 2008 03:01 PM
Jose-aka-Pedro
Jun 14, 2007 06:37 AM
jm85rx7
Mar 30, 2004 07:45 PM
