integra brakes with 14" rims
i did do some searching. may have typed the wrong search words, but i didnt find much.
i'm wanting to put teggy front brakes up front on the hatch. i've got some 84-87 crx si rims on it now (oldskool
) that i'd liek to keep on the car. i've seen threads about shaving the calipers with hx rims. and i know some lower model tegs come with 14" steelies stock. basically i want to keep the crx rims.
so is there a certain offest needed to keep 14" rims and run the brakes or what size spacer would i need to get (with some extended lugs)? thanks for any and all help
) that i'd liek to keep on the car. i've seen threads about shaving the calipers with hx rims. and i know some lower model tegs come with 14" steelies stock. basically i want to keep the crx rims. so is there a certain offest needed to keep 14" rims and run the brakes or what size spacer would i need to get (with some extended lugs)? thanks for any and all help
well, I know 90-91 crx 14" rims do NOT fit over the integra brakes without modification. so you may get lucky with yours, but you might need to shave the caliper and/or run a small spacer.
There's a picture floating around on here of some 14 inch bronze TE37's over some ITR brakes I believe they are. It's quite cool looking.
Rim, offset and spoke design play a large factor in what will and won't fit.
14" del sol rims will clear integ brakes. they were actually sold at acura dealerships also as factory acccessories (with acura badges of course). most 14" steelies will clear integ brakes also (ex it-r). i have a 14" steelie in place of my donut spare b/c it wouldn't clear my front teg brakes.
well these are what i'm rocking now and theyre 14s. and like i said in the 1st post i'd like to keep them on.
and to the guy who talked about the del sol rims... do you mean these rims...
or these?
dont mind the polish lip it was the first pic of that wheel i could find.
or these?
stuff215
Jul 12, 2007 06:59 PM
