i need a strut...your advice please
Old Feb 10, 2005 | 07:58 PM
SIMATIC's Avatar
Default i need a strut...your advice please
i got a 98 accord ex
140k 5speed runs great
i need a front right strut. i know if i get new struts i wouldhave to replace the both the left and right ones's...well i was thinking to save my self some money, i wanted to go to the junk yard and pick up a strut from a junk accord and install it. do you guys think its worth doin that to save myself the money???? i mean with the money i save from the seocnd strut i can probably buy an o2 sensor i need. if one strut is bad, does that mean the other is one it way out too? thanks for the advice and help
Old Feb 11, 2005 | 05:29 AM
sj993's Avatar
Default Re: i need a strut...your advice please (SIMATIC)
Possibly, like you said if you have to replace one you have to replace the other side as well. You could go to a junkyard and get a salvage one though I don't think I'd do that myself. How much are two struts from Honda? You can always go aftermarket which, in some cases would be cheaper.
Old Feb 11, 2005 | 07:13 PM
SIMATIC's Avatar
Default Re: i need a strut...your advice please (sj993)
aorund 249 installed not OEM though
Old Feb 11, 2005 | 07:36 PM
jb.'s Avatar
jb.
you could look online and get some tokico blues or kyb struts for that price
Old Feb 11, 2005 | 08:03 PM
daich's Avatar
check my sig
Old Feb 11, 2005 | 08:06 PM
daich's Avatar
basically got new springs (pro kit eibach)
When I installed them, I scored up the shaft on the rear struts (stinking bolt was on there soooo tight) so I had to replace the rear struts. Since I bought all four struts (they were cheaper that way) I have two extra fronts. I thought the GR2's were OEM replacements e.g. they ride the same. As far as the ride it may be a smidgen stiffer but over all it's the same, the only difference is the strut body is significantly thicker and seemed much more heavy duty then the OEM ones.
Old Feb 11, 2005 | 08:07 PM
daich's Avatar
Default Re: i need a strut...your advice please (daich)
btw, I looked for KYB AGX. don't bother looking. They don't make them for our 6th gens yet.
Old Feb 12, 2005 | 01:29 AM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daich &raquo;</TD></TR><TR><TD CLASS="quote">btw, I looked for KYB AGX. don't bother looking. They don't make them for our 6th gens yet.</TD></TR></TABLE>
they said they will..they promised me...back in 1998
Gr2, tokico blue, koni red, will do it
Bobby01
Dec 12, 2007 09:04 PM
streetspeed607
14
Nov 5, 2007 04:34 AM
SIMATIC
Feb 26, 2005 11:43 PM
SIMATIC
Nov 7, 2004 03:40 PM
