coolant line question
did a search to find out if i could get some info on how to hook up the coolant lines on my inatke manifold since im rebuilding the z6, any how when i took them of i forgot to make a diagram and the damn books i have are not honda shop manuals so they dont help. in the search i saw something bout not using some of the lines wont that effect the iat sensor or one of the others (code 10 and 14) just wanted to know if some one could get me a link on how to hook them up the right way thank you
o.k. so since no one wanted to help me i decided to help myself. still don't know if they are hooked up right but this is what i got.
1.on the z6 mani looking at the front(exhuast side) of the motor i took the small hose from the bottom right of the motor just below intake mani (water pump side) and hooked it up to the iat
2. from the other side of the iat i ran a hose to the metal line going under the t/b
3. from other side of t/b set up i ran a hose to the nipple on the top of intake mani on left side(just behind v-tec selonoid)
4.side not heater core hoses and rad hoses are hooked up they were easy
5.then i took a hose and looped from the small nipple on by the thermostat housing(next to upper rad hose connection) to the nipple on the coolant feed metal tube that goes to the water pump. nipple is just below intake mani on the alternator side of the engine.
please inform me of any errors asap thank you always appretiate the help when i get it.
92cb7sk8er
14
Mar 21, 2011 07:43 PM
Frost7177
Oct 5, 2009 06:07 PM
