D15b in 93 Lx 4d...
where can i find some info on the wiring on this motor...the harness's have been cut...i don't want to wire it up wrong and get disaster...i would appreciate the help...this is my first swap...so if you have any tips i would appreciate them...thx
I believe wiring should be the same , you are going to need to wire it up for vtec , I'am not sure if you can use the 4wire 02 with the p08 ... you definetely can if you are going to be using a p28 ...
well i am running the p28...D15b with an z6 tranny and soon to be turbo with about 7psi...hopefully putting down bout 180 190'ish....but if you have any tips on techniques for pulling the motor that would be helpfull too...thx
i did mines through the top , just disconnect the engine harness from the engine ,,, and don't unplug any of the shock tower plugs... just unplug all the connections on the engine , and leave it hanging way in the back, pull it up some by the firewall .... before you drop the new engine in.
GSRCRXsi
Engine Management and Tuning
16
Feb 13, 2013 12:53 PM
Markb16a
Nov 17, 2005 05:56 PM
tsjeff
Apr 10, 2005 07:15 PM
spyderracing
Aug 10, 2004 08:02 PM
