Possible dirty fuel injectors cause of code 71/72?
Old Feb 10, 2005 | 06:59 PM
sk8's Avatar
sk8
Default Possible dirty fuel injectors cause of code 71/72?
I keep getting code 71/72. I have changed all the usual stuff( Plus, wires, cap, rotor, battery)
Once in awhile, it will start with seems to be a misfire. It will run really rough. I'll keep driving it, and when it gets up to operating temp, it will usually stop blinking check engine, and run ok.
What could be the possible causes? I'm too cheap/don't want the hassel, to take it in and have it fixed.
Old Feb 10, 2005 | 08:07 PM
SpdFrk's Avatar
Default Re: Possible dirty fuel injectors cause of code 71/72? (scott k)
I had the exact same problem, changed everyting you descibed except the battery and still misfied on all cylinders until i took out my injectors and had them cleaned, fixed the problem. No more misfires at all.
Old Feb 11, 2005 | 09:20 AM
type r 01-1063's Avatar
Default Re: Possible dirty fuel injectors cause of code 71/72? (SpdFrk)
Can cleaning the injectors be a do it yourself kinda job? or it has to be taken to a shop?
Old Feb 11, 2005 | 10:01 AM
cheezthis's Avatar
Have you used Regane Injector Cleaner yet? It's around $5, and is what I have used for years. It's worth a shot.
Old Feb 11, 2005 | 10:27 AM
Mugen Mike's Avatar
Default Re: Possible dirty fuel injectors cause of code 71/72? (type r 01-1063)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type r 01-1063 &raquo;</TD></TR><TR><TD CLASS="quote">Can cleaning the injectors be a do it yourself kinda job? or it has to be taken to a shop?</TD></TR></TABLE>
Other than using a fuel additive type injector cleaner, I'd leave it to the professionals.
http://www.rceng.com/service.htm#INJECTOR
Old Feb 11, 2005 | 01:09 PM
SpdFrk's Avatar
I took them out and had a shop clean them. That fuel cleaner stuff doesn't really work to well.
Old Feb 11, 2005 | 02:01 PM
chad's Avatar
Moderator
71-72 usually a bad gas cap!
Old Feb 11, 2005 | 07:07 PM
sk8's Avatar
sk8
Default Re: Possible dirty fuel injectors cause of code 71/72? (chad)
I do have an autozone special.!
thanks to all.
CCCP-ef
Sep 13, 2008 06:11 AM
Maxpower350
11
Jul 3, 2006 10:00 PM
redrocketgsr
Aug 19, 2004 11:13 PM
delux247
Jan 28, 2004 11:48 AM
slowdx
16
Jan 23, 2004 08:20 AM
