hondata intake gasket for the R, come with washers or longer studs?
i was under the impression it came with some washers and longer studs but mine didnt have anything. those of you with it on your R, do you need those extra parts or just the gasket in order to install it?
its just the gasket and some washers that go between the nut and stud to add more insulation.
b19coupe (on his itr motor) has big ol' studs plus a honda oem gasket acting as a sandwich between the hondata gasket
his motor makes good power
I got mine a few weeks ago when ordering I asked and was told the washers are only necessary for if you order the race version. If you just have the normal one with the coolant bypass cutout then you don't need the washers and obviously don't need longer studs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime »</TD></TR><TR><TD CLASS="quote">Its just a gasket.
Check this out.... http://www.outlawengineering.com</TD></TR></TABLE>
I like the way that looks...
is there anyone here that has real world experience with it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso »</TD></TR><TR><TD CLASS="quote">I like the way that looks...
is there anyone here that has real world experience with it?</TD></TR></TABLE>
Its on my car... found out about it through some guys I know in MI. I was very impressed with the thickness and the completeness of the kit. And there was a very nice notable drop in the IMs temp. Nothing datalogged... just using my hand dyno...
roller3804
Oct 23, 2007 03:04 PM
