rebuilt motor and now car wont drive...
Old Feb 10, 2005 | 02:24 PM
boostmywankle's Avatar
Default rebuilt motor and now car wont drive...
ok so yeah i rebuilt my b18c block and it runs but when i put the car in gear, and let the clutch out...Nothing...does anyone know what i might have done wrong when i put the tranny back in??
Old Feb 11, 2005 | 03:35 AM
Default Re: rebuilt motor and now car wont drive... (96teggyls)
does anyone know?????
Old Feb 11, 2005 | 06:06 AM
up! comon somone has to know
Old Feb 11, 2005 | 07:15 AM
SlowReaction's Avatar
Have someone pump the pedal as you look at the slave cylinder to see if there any movement. You sure the clutch was install properly?
Old Feb 11, 2005 | 07:57 AM
Default Re: rebuilt motor and now car wont drive... (SlowReaction)
im pretty sure it was installed right
Old Feb 11, 2005 | 08:15 AM
If the car running and it goes in gear but it wont engage, the only thing I can think of is the pressure plate is bolted on wrong.
Old Feb 11, 2005 | 08:23 AM
thatbluecrx's Avatar
make sure ur axles are in right
Old Feb 11, 2005 | 09:15 AM
Default Re: rebuilt motor and now car wont drive... (thatbluecrx)
fuckkk...cant the pressujre plate only be bolted on one way!?
Old Feb 11, 2005 | 09:25 AM
Penfold's Avatar
Is the car on jack stands?
I did a clutch job once on my old honda, and when in gear on stands it wouldn't turn the wheels.
As soon as i let it down onto the ground, it worked fine.
I have no explanation as to what caused it.
Old Feb 11, 2005 | 10:05 AM
Default Re: rebuilt motor and now car wont drive... (Captain Obvious)
it still is on jackstands....but that doesnt make sence....like the speedo doesnt go up or anything
Old Feb 11, 2005 | 10:37 AM
Penfold's Avatar
If you set it back onto the tires, and it still doesnt work, the only thing i can think of is that the clutch disc is on backwards. I think that is what the person ment when they said pressure plates.
Old Feb 11, 2005 | 11:06 AM
ok **** i hope the clutch disk isnt in backwards! that will be a pain in the ***!
92sully
Sep 6, 2010 01:18 PM
The Weather Man
Jul 3, 2006 08:30 AM
scrEaMO Kyle
Nov 3, 2005 03:43 PM
paybac4223
Oct 28, 2002 03:01 PM
