Code 41 + limp mode= searched
Would a code 41 send the car into limp mode??
I'm thinking no since it's only there to help at start up right??
Oh its a 4 wire with VX wiring and a p28 w/z6
I have 6 wires,VX, that are for the o2... is that normal, helms has 7 wiresl?? blk, orn/blu, grn/wht, wht, yel/blk, orn
Umm...did you re-wire things so that you can use the 4-wire O2 with the VX harness?
Obviously the VX wideband connetor isn't compatible with the standard 4-wire connector.
Yeah i did, spent a good couple hours staring at the wiring diagrams and then figuring out what wires i could use and which wire had to be spliced
bobbysteelz
Aug 4, 2003 05:16 PM
bobbysteelz
Aug 4, 2003 05:07 PM
