vtec wiring and cooling ques.
Old Feb 10, 2005 | 12:40 PM
BadRelge45's Avatar
Default vtec wiring and cooling ques.
Got a 98 r motor in a 95 civic hatch with a p28 ecu. What exactly do i have to wire for vtec? Secondly, the radiator in the civic does't seem to have the same sized outlets as the r motor and the hoses don't fit. Do i have to get a type r radiator and hoses?
Old Feb 10, 2005 | 12:43 PM
DJ_SaNdOz's Avatar
Default Re: vtec wiring and cooling ques. (BadRelge45)
Do you have a pressure switch on the motor w/ the VTEC solenoid, or is it just the solenoid?
Old Feb 10, 2005 | 12:59 PM
BadRelge45's Avatar
Default Re: vtec wiring and cooling ques. (DJ_SaNdOz)
there's a green and white wire coming from the solinoid to a plug. And a green plug under that. i guess thats the oil pressure
Old Feb 10, 2005 | 01:17 PM
BadRelge45's Avatar
found the answer to the vtec quest. Just need to know about the radiator
Acidcrakker
Nov 8, 2007 02:39 PM
I_aM_a_nO0bIe
Nov 7, 2006 01:33 AM
KY
Dec 22, 2004 05:46 PM
Macleod95Civic
Nov 3, 2004 08:54 AM
