What is average compression in each cylinder for my this setup?
Old Feb 10, 2005 | 11:32 AM
MysteryWagon's Avatar
Default What is average compression in each cylinder for my this setup?
I have Lsvtec with usdm ITR slugs, milled head stock layer head gasket.
I am guessing 11.5 compression
My compression test on fresh rebuild was about 210 across the board, is that lowor normal. What should it be.
thanks
Justin
oh yeah I have BC3+ cams, does duration take in count for the compression #'s
Old Feb 10, 2005 | 11:38 AM
Shocky's Avatar
Default Re: What is average compression in each cylinder for my this setup? (MysteryWagon)
i only have PCT pistons and i have 225psi on each cylinder
Old Feb 10, 2005 | 02:17 PM
CHEETAH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MysteryWagon &raquo;</TD></TR><TR><TD CLASS="quote">I have Lsvtec with usdm ITR slugs, milled head stock layer head gasket.
thanks
Justin
oh yeah I have BC3+ cams, does duration take in count for the compression #'s</TD></TR></TABLE>
its fine the bc3 can chg dynamic compression quite a bit ... keep in mind that you can't compare to other similar motors with stock or smaller cams ...
greg
Old Feb 11, 2005 | 08:50 AM
Default Re: What is average compression in each cylinder for my this setup? (CHEETAH)
thats what I was bringing to a conclusion.
thanks
Old Feb 11, 2005 | 09:18 AM
faSHOwidIT's Avatar
250-255 with ctr slugs and crower stage 3 cams.
skippy33
Feb 7, 2021 05:34 PM
pootie.teng
Jun 2, 2005 10:32 PM
aut0tek
Mar 18, 2003 11:00 AM
