gauges want work need some help
i have a 90 integra and i cant see at night i have replaced all the fueses in and outside the car none of the gauges work gas,coolant,all the insterment lites climet control the lights on the shifter, radio,turn signals hazards, only thing that works is the head lights interor lights door locks and windows......
i have herd about a relay might be bad but i dont know witch one i have looked under the dash does anyone have any info for me
try the dimmer switch.. if that thing is unplugged then the dash lights won't come on. just pop out your cluster frame thing.. two screws at the top and push on the dimmer **** from the back and it will pop out.. check to make sure the harness is connected.
Do the gauges NOT WORK or are they NOT LIGHTING UP? If it's just a problem with the lights, then do what they suggested above. If the gauges themselves aren't working I think there might be something a little bigger going on.
oh.. i must have misread your post then. the dimmer switch would only effect the lighting.. you're gonna have to take the entire cluster out and check the plugs in the back.. its simple.
bambam530
Oct 27, 2013 07:12 PM
Jonathan_ED3
11
Aug 25, 2005 03:47 PM
