Management with Nitrous can I use a Chipped Ecu?
Old Feb 10, 2005 | 08:17 AM
EM1_GIL's Avatar
Default Management with Nitrous can I use a Chipped Ecu?
Hello all my current set-up is :
00 civic si
cai
apexi ni
skunk2 im
zex 55 shot dry
all my buddies are running chipped p28 with all motor gsr's in hatch and we are all good runs about mid 14's on the 1/4
so all of us agree the ecu is the most cost effective upgrade in their set-ups i am looking into getting one but it advances timeing and i know required to retard timeing to run a higher shot with the zex kit. so maybe the ecu isn't right for me???
any recommendation and a management to help always but also when i spray?and i am on sort of a budget.
Old Feb 10, 2005 | 10:08 AM
thumbtack's Avatar
Default Re: Management with Nitrous can I use a Chipped Ecu? (EM1_GIL)
do not get one of the ebay "spoon or skunk or jun" chips... those just adavance the timing and lean out your fuel so you can blow your engine using that with nitrous.
Look into getting Uberdata with the P28 not for boost, but for the ability to adjust the fuel maps in not only vtec fuel maps, but the rest of the fuel band too.
Good luck.
Old Feb 10, 2005 | 10:25 AM
EM1_GIL's Avatar
Default Re: Management with Nitrous can I use a Chipped Ecu? (thumbtack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thumbtack &raquo;</TD></TR><TR><TD CLASS="quote">do not get one of the ebay "spoon or skunk or jun" chips... those just adavance the timing and lean out your fuel so you can blow your engine using that with nitrous.
Good luck.</TD></TR></TABLE>
no i was not talking about those cheap 20 dollar chips but the outcome would probably be the same.
Old Feb 10, 2005 | 10:36 PM
FLOWZILLA's Avatar
the best thing to do would be to go with a hondata system a chipped ecu does in fact advance timing and lean out " a deadly combination for your motor"hondata will give you all the options you will need to finely tune your car..
Old Feb 11, 2005 | 07:23 AM
SlowReaction's Avatar
Default Re: Management with Nitrous can I use a Chipped Ecu? (FLOWZILLA)
You never know what your getting with those chips but most of them have advanced timing in the upper rpm which is bad for nitrous. Your better off running a stock ecu. Since its only a 55 shot i say just buy a walbro 255 and a fpr. The dry shot relys on the fuel pressure. While your sqeezing your fuel pressure will be bumped up to help out the nitrous/fuel mixture. The fuel pump will help keep the pressure steady so there no drop or anything. Use the fpr to tune the pressure beacuse with the pump alone you will get about 50psi at idle and factory is about 38psi.
Old Feb 11, 2005 | 09:01 AM
EM1_GIL's Avatar
Default Re: Management with Nitrous can I use a Chipped Ecu? (SlowReaction)
thanks this is some helpful info
Q: hondatas boost option is that only for turbo or nitrous a well?
fatpride111
Sep 13, 2007 02:56 PM
teefunk01
Sep 6, 2005 05:26 PM
Euro98ITR
Sep 22, 2003 11:13 PM
dvp95
Aug 20, 2003 05:31 AM
KCDelSol
May 11, 2003 06:40 PM
