is there a difference between 88-89 and 90-91 crx si pm6 ecus?
Old Feb 10, 2005 | 06:59 AM
MtnCRX's Avatar
Default is there a difference between 88-89 and 90-91 crx si pm6 ecus?
well, is there?
Old Feb 10, 2005 | 07:03 AM
EP3_05's Avatar
Default Re: is there a difference between 88-89 and 90-91 crx si pm6 ecus? (MtnCRX)
Yes....
Something I learned a couple days ago on here:
The rev limits are slightly higher on the 90-91 ecus
Also the 88-89 cannot be chipped as easily as the 90-91 ecus
As far as I know those are the only differences.
Old Feb 10, 2005 | 07:10 AM
MtnCRX's Avatar
Default Re: is there a difference between 88-89 and 90-91 crx si pm6 ecus? (91civic)
hmm ive heard about these chipping issues also. anyone know the rev limit difference? i have 3 pm6's and im wondering if simply goin from a 89 to a 90 will help rev limits any. thanks for the quick reply by the way
Old Feb 10, 2005 | 08:38 AM
ssl2k's Avatar
You are not going to notice any different by revving a little bit higher with your a6.
unless you plan on chipping your ecu don't waste the time switching them.
Old Feb 10, 2005 | 09:06 AM
M-doc yo!'s Avatar
Default Re: (ssl2k)
chipping wise the 88-89 will more than likely lack the external eprom, the 90-91 ecu is equipped with this.
If you are just gonna run the ecu stock, no chipping or nothing, just wanting something a tad bit better, go get a PG7 ecu.
Old Feb 10, 2005 | 05:55 PM
MtnCRX's Avatar
Default Re: (soyouwannabejdm)
i will be chipping in the future, so ill hold on to the 90, but wont put it in. btw, is turboedit the only obd0 standalone i can run?
Old Feb 10, 2005 | 06:28 PM
crxdonwon's Avatar
the 88-89 si is 6500 and the 90-91 si 6800. The pg7 out of the 88-89 integra is the way to go though, from what I heard.
Old Feb 10, 2005 | 06:31 PM
crxdonwon's Avatar
Default Re: (MtnCRX)
check out the WHAT ECU '90 CRX thread, I had a lot of the same questions, well except the last one.
Old Feb 10, 2005 | 06:40 PM
mellon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MtnCRX &raquo;</TD></TR><TR><TD CLASS="quote">i will be chipping in the future, so ill hold on to the 90, but wont put it in. btw, is turboedit the only obd0 standalone i can run?</TD></TR></TABLE>
ghettodyne, I haven't personally used it but it looks pretty cool...
Old Feb 10, 2005 | 07:27 PM
pyro_freak8's Avatar
yes your options for OBDO map editing are:
TurboEdit(my favorite), Ghettodyne(no longer being updated), and OBDO edit
Old Feb 11, 2005 | 03:02 PM
MrPotatoeHead's Avatar
Default Re: (pyro_freak8)
The 90-91 revs to bout 7200
The 88-90 revs to 6800
88CRsXy
18
Jun 12, 2006 12:28 PM
Wilson_
Feb 11, 2006 12:31 PM
mR. Vash
Jul 26, 2004 08:51 PM
wpgcivic
11
Jan 20, 2004 07:41 PM
Crxfanatic15
Jan 25, 2003 04:23 PM
