bolt broke off in head.help please.
Old Feb 10, 2005 | 06:21 AM
PHILLIPDEEZ's Avatar
Default bolt broke off in head.help please.
last nite i was workin on my civic and i put the valuve cover back on and the screw in the back right next to the coolant line broke off it broke right at the end of the threat so i can see the screw in the hole if i remove the valve cover.how can i gte it out i tried to drill it broke two bits . its a single cam vtec the screw is a about a 1/4 of an inch in the hole so what can i do?please help?
Old Feb 10, 2005 | 07:29 AM
georgj's Avatar
Default Re: bolt broke off in head.help please. (PHILLIPDEEZ)
Try using a set of "easy outs".
Old Feb 10, 2005 | 09:04 AM
debo*'s Avatar
Default Re: bolt broke off in head.help please. (georgj)
drilling it out will probably be the only way. gl
Old Feb 10, 2005 | 09:23 AM
Contraband's Avatar
machine shop. like $10 bucks
Old Feb 10, 2005 | 10:04 AM
d16rice's Avatar
DO NOT do it yourself
I had that happen, too. Local shops charge $10-25 to take those out. The tools alone cost that much, plus if you mess up, patching it up will run you up to $50.
Don't be stingy and do it right the first time, take it to a shop.
I had my whole head done a "Built Rite" engine builders and couldn't be happier
$250 for a valve job, milling, fixing the broken bolt, new valve seals, cam seals, etc.
Old Feb 10, 2005 | 06:05 PM
DOHC_VTEC69's Avatar
Default Re: (LS95eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LS95eg &raquo;</TD></TR><TR><TD CLASS="quote">machine shop. like $10 bucks</TD></TR></TABLE>
Old Feb 10, 2005 | 06:21 PM
SOHCD16y8's Avatar
Default Re: (DOHC_VTEC69)
for 10 bucks just do it right
Old Feb 10, 2005 | 10:23 PM
Default Re: (SOHCD16y8)
well i took it to several shops no one can get it out so for the mean time the bolt is seal in with hondabond its holding up well and the guy said it should hold cause he had two bolts on his head held down wiht hndabond cause he snapped and he was boosting on his single cam so im not too worried about it i may just le tit chill till i save up for my b16 but i kinda want the knowledge of taking off the head to better prepare me for the b6 swap since im thinkin bou tbustin a DIY on it.but thanks guys
Old Feb 11, 2005 | 09:14 AM
Race Whore's Avatar
I agree don't do it your self do it at a shop they are experts in taking it out. Try to call around more because trust me trying to get it out will only make it worse.
Animefun
Oct 28, 2012 08:55 PM
deebo's ek9
10
Sep 30, 2010 10:01 PM
neoekai
May 16, 2008 05:27 PM
00ekcoupe
37
Sep 5, 2005 06:15 PM
hondaracin24
May 10, 2005 04:38 PM
