need help bad
Old Feb 10, 2005 | 04:44 AM
evilsolb16's Avatar
Default need help bad
we put a ZC motor in to a civic dx, converted to wiring harness to mpfi, the cars is running but real bad. it bogs when you give it gas or rev it up. when it does rev up it sounds like its hitting rev limiter. the car will only rev to 1500-2000 rpm and then the rev limiter hit and it kinda backfires. we check timing and reput it in time and checked wiring, we are throwing 1 cel. #4 thats the crank angle sensor, all injectors are firing and all cylinders are getting spark. can anyone please help out. thanks
Old Feb 10, 2005 | 08:06 AM
evilsolb16's Avatar
Default Re: need help bad (evilsolb16)
anyone have any info that could help
Old Feb 10, 2005 | 08:34 AM
ssl2k's Avatar
What ECU are you using?
Did you solder all of your wires?
Old Feb 10, 2005 | 08:59 AM
nummbr7's Avatar
Default Re: (ssl2k)
did you switch the wires on the throttle position sensor? because on dpfi it works backwards
Old Feb 10, 2005 | 09:01 AM
PHOBIA's Avatar
well if its telling you your c.a.s is bad then get another one.as soon as you start it does it put itself into limp mode?
nummbr7's Avatar
Default Re: (nummbr7)
also what did you go by to convert the harness?
Old Feb 10, 2005 | 05:07 PM
evilsolb16's Avatar
i am running a pg7 ecu i do believe, it is the one for the zc motor, i got the wiring diagram form hondaswap.com and i also found 2 other sites with the same info just worded different. its there a way that i can convert a si distributor with the CAS in it to take place of the one on the exhaust cam.
acurateggy93
Jul 26, 2005 08:06 PM
91sleeper
May 31, 2004 10:55 PM
Ronin Panda
Jul 17, 2003 02:23 PM
89dohcEF
Jul 16, 2003 12:47 PM
EK22Tim
Nov 27, 2002 06:37 PM
