EF dash wiring harness...
Old Feb 9, 2005 | 11:38 PM
BR's Avatar
BR
Default EF dash wiring harness...
If the dash wiring harness is not attached to the rest of the car, will the engine fire when you turn the key??
I just put my c1 from my teg into my 89 std hatch and I cannot get it to turn over when I turn the key. I converted to a full Si wiring harness throughout the car, but the only part of the wiring I dont have yet is the dash harness.
I can turn it over when I jump 12v from the battery straight to the starter solenoid, but I get no voltage to the starter from the ignition switch.
I do have 12v coming from the switch to the dash fuse panel, but I havent figured out the whole routing for the system after that...
Any and all help is greatly appreciated...
Later,
BR
Old Feb 10, 2005 | 06:45 AM
PrettyLude's Avatar
hit JimBlake up, he is a whiz at electrical stuff
Old Feb 10, 2005 | 12:29 PM
gsrswapdcivic's Avatar
check all grounds and make sure that the signal wire is going to the starter
unuselectus
10
Nov 18, 2018 07:19 PM
tooslow1
Mar 3, 2010 03:40 AM
gummiegorilla
Jul 30, 2009 07:32 PM
ParistsCP
May 7, 2006 07:16 AM
eagleclawracing
Jan 24, 2006 04:09 PM
