Oxidized Bolts in the Engine Bay How to Clean?
Old Feb 9, 2005 | 07:20 PM
01-0720's Avatar
Default Oxidized Bolts in the Engine Bay How to Clean?
well tommarow im going to detail my car, inside and out, clean the engine bay, shampoo the carpet and seats, the works
one thing i noticed the last time i looked under the hood is that most of the gold bolts under my hood are oxidized, i was wondering the best way to clean them, to make them look new again
i was thinking simple green and either a harsh brush or brillo pads
also on a unrealted note, the previous owner apparently had the fender repainted for some reason, and the paitner got a little over spray on the vin sticker on the top of the fender in the engine bay, i was wondering if anyone knew of a way to get that paint of the sticker, its always bugged me and since im going to be in the bay cleaning tommarow i figured id take care of that to, i was thinking maybe a little simple green and maybe claybar it i dunno
thanks for any help
Old Feb 9, 2005 | 08:22 PM
acuracy r's Avatar
Default Re: Oxidized Bolts in the Engine Bay How to Clean? (01-0720)
id like to know as well... for maryland
Old Feb 9, 2005 | 09:25 PM
Bbasso's Avatar
Simple Green w/o the harsh brush should work on the bolts. If not try some hot water and baking soda with a soft brush. ( that works on batteries with build up)
paint thinner on a Q-Tip and very very easily with a ton of patience wipe the over-spray a way.
Old Feb 10, 2005 | 02:30 AM
KayOs's Avatar
You could always paint them
Old Feb 10, 2005 | 03:43 AM
ebelp's Avatar
Default Re: Oxidized Bolts in the Engine Bay How to Clean? (KayOs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KayOs &raquo;</TD></TR><TR><TD CLASS="quote">You could always paint them </TD></TR></TABLE>
Well you still have to remove the oxidation before you paint them so....
Old Feb 10, 2005 | 07:38 AM
white rocket's Avatar
Default Re: Oxidized Bolts in the Engine Bay How to Clean? (Bbasso)
[QUOTE=Bbasso]Simple Green w/o the harsh brush should work on the bolts. If not try some hot water and baking soda with a soft brush. ( that works on batteries with build up)[QUOTE]
I was about to ask this very same question. What about exposed cam gears? Should I be concerned about water getting in there?
Old Feb 10, 2005 | 07:42 AM
Opie's Avatar
They're just going to get oxidized again, I've replaced tons of broken bolts in my engine bay and they all look equally crappy after a few times or rain driving.
Old Feb 10, 2005 | 01:41 PM
BudMan's Avatar
Default Re: (opie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opie &raquo;</TD></TR><TR><TD CLASS="quote">...I've replaced tons of broken bolts in my engine bay...</TD></TR></TABLE>
Maybe you should start using a socket instead of a sledge-hammer to loosen them?
**Opie is going to chase me down at the expo with da ball bat if I keep teasing him
Old Feb 10, 2005 | 01:46 PM
uNF$@#!'s Avatar
Default Re: (BudMan)
take the bolt, throw it in table salt, and vinegar. oxidation = bye bye
then clean off with wd40.
dry, then go nuts either with antiseize or paint them. lol. i'd go nuts with the antiseize, if you really care.
Old Feb 10, 2005 | 01:54 PM
Mugen Mike's Avatar
Claybar should take care of the overspray.
Old Feb 11, 2005 | 02:07 PM
Honda97's Avatar
Default Re: Oxidized Bolts in the Engine Bay How to Clean? (Mugen Mike)
spary LIMEAWAY on it, the clean it off with tin foil
Old Feb 11, 2005 | 02:39 PM
KayOs's Avatar
Works wonders for me and all the rusty parts I encounter:
http://eastwood.com/shopping/p...027zp
Old Feb 11, 2005 | 04:04 PM
92TypeR's Avatar
FSAE
I use aluminum jelly. Should be able to find it at any auto parts store.
91efbluehatch
Jul 31, 2011 09:05 PM
trepteg
Mar 31, 2008 08:02 AM
jlh22179tx
10
Mar 11, 2007 05:53 PM
kkw103
May 17, 2003 01:45 PM
MugenFG360
Sep 28, 2001 01:29 PM
