Headlight...one lower beam then the other
Old Feb 9, 2005 | 06:32 PM
JFG Kevin's Avatar
Default Headlight...one lower beam then the other
My passinger side has alway been lower beem then the other. I have a 98+ frontend. I tried changing the lamp and it's still the same. Does any other people have the same problem.?
Old Feb 9, 2005 | 06:38 PM
SOHCD16y8's Avatar
no but there is that little adjuster thing on the assembly
Old Feb 9, 2005 | 07:10 PM
JFG Kevin's Avatar
Default Re: (SOHCD16y8)
If i'm not wrong i believe those are to help level out where your aiming your light
Old Feb 9, 2005 | 07:34 PM
dawalude's Avatar
Default Re: Headlight...one lower beam then the other (aznstyler119)
isnt that your problem? that the beam is lower than the other like ur topic says? if so thats what the adjuster is for. do u mean one headlight sits lower than the other? be a lil more specific
Old Feb 9, 2005 | 09:08 PM
2G0S0R1's Avatar
New User
Do you mean dimmer? Swap the bulbs and if it is the same, then you have other problems than the bulbs.
Old Feb 9, 2005 | 09:11 PM
Don_Vito's Avatar
I think i have the same problem, but my driver side light, beam is angled down and my passenger lights goes str8 out into the distances
Old Feb 9, 2005 | 09:20 PM
JFG Kevin's Avatar
Default Re: (Don_Vito)
yes...that's what i meant...my passinger lighting is lower then my driver side light. I know for sure it's not my bulbs well at least i'm pretty sure....i been throught like 3-4 pairs of 9005 converation and it's been teh same
Old Feb 10, 2005 | 12:19 PM
Thrasher's Avatar
Isnt the passenger side light supposed to be higher? To light up road signs. And the driver side is lower so not to blind oncoming traffic?
Old Feb 10, 2005 | 12:45 PM
5 Speed AP2's Avatar
I ran into the same problem with a friend's EP3. All it came down to was a 10 or 20 fuse in the engine bay. Good Luck.
Old Feb 10, 2005 | 07:32 PM
JFG Kevin's Avatar
Default Re: (5 Speed Dc2)
intestering.. i never mess with the headlight fuses. but i highly doult that it's the fuses. which fuse is it suppose to be in there
Old Feb 10, 2005 | 07:36 PM
JamaicanDM's Avatar
Default Re: (aznstyler119)
ma passenger side is kinda dimmer tooo
Old Feb 10, 2005 | 10:03 PM
JFG Kevin's Avatar
Default Re: (JamaicanDM)
so is this suppose to happen or somethings wrong? do you think buyin hid wil help...or it will have the same problem...i dont wnat to buy it tho..
Old Feb 11, 2005 | 03:24 PM
http://www.honda-acura.net/for...45651 <---Its the fuse in the middle of the fuse box cover that says "Head Light". You should also have a spare 40 in the fuse box jus incase it is the fuse.
Sparkomatic
Honda CR-V & Element
Nov 16, 2013 01:03 PM
rayccfhk
Jan 17, 2008 01:28 PM
wink11290
Jul 6, 2007 01:16 AM
NewBorn_EG
Nov 14, 2004 04:08 AM
Weapon_R
Nov 12, 2004 07:29 PM
