itr swaybar & beaks kit
Old Feb 9, 2005 | 06:32 PM
dohcroc's Avatar
Default itr swaybar & beaks kit
whos is runing this setup. i plan to do it but some people have said that the beaks kit will not help to protect the subframe and it will tear it even with it on the itr swaybar. so please help me out
Old Feb 9, 2005 | 06:43 PM
timmy8151's Avatar
Default Re: itr swaybar & beaks kit (dohcroc)
Beaks kit will be fine. If you want to save some money get the BSQ kit. I've run the ITR sway with BSQ kit for almost 2 years without any problems.
Get the BSQ kit at: http://www.geocities.com/bretq
Old Feb 9, 2005 | 07:15 PM
Racermech's Avatar
Default Re: itr swaybar & beaks kit (timmy8151)
The only reason i know have a ITR and BSQ kit on my car is because of all the people here on HT that have it on there car, and have said it worked without any problem. Then only sub frame damage i have seen is from people that did not use any mounting kit.
Old Feb 9, 2005 | 07:21 PM
njandrewg's Avatar
Default Re: itr swaybar & beaks kit (Racermech)
i hear you can't use the BSQ kit if your car is lowered more than 2 inches, because u'll be damaging your abs lines
Old Feb 9, 2005 | 07:22 PM
Vtecfool's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcroc &raquo;</TD></TR><TR><TD CLASS="quote">whos is runing this setup. i plan to do it but some people have said that the beaks kit will not help to protect the subframe and it will tear it even with it on the itr swaybar. so please help me out</TD></TR></TABLE>
No i'm running the beaks kit and it works fine. Very strong pieces.. i think your mistaking people who just run it on their subframe with no mounting kit.
Old Feb 9, 2005 | 08:43 PM
Lord Helmet's Avatar
If you want to protect the subframe damage then get this: http://a-spec-racing.com/products.php
I don't trust the beaks kit after one of two people on this site showed a beaks kit w/ ITR sway bar with a torn subframe.
Old Feb 9, 2005 | 08:49 PM
njandrewg's Avatar
those are all for civics
Old Feb 9, 2005 | 09:01 PM
Default Re: (njandrewg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by njandrewg &raquo;</TD></TR><TR><TD CLASS="quote">those are all for civics</TD></TR></TABLE>
integra and civics have the same chassis.
meaning EVERYTHING are interchangeable except the some parts of the ITR
Old Feb 9, 2005 | 09:27 PM
njandrewg's Avatar
Default Re: (sleeperciv)
i know that civic and integra share a lot of things...I was wondering why the site didn't designate that
Old Feb 10, 2005 | 01:14 AM
sumyungguy's Avatar
i dont know if the abs lines would clear that kit
ohh yeah
the prson i bought my car from(original owner) was an acura mechanic that replace the stock gsr rear sway with a '97 type r.. i do heavy cornering and my car is prety low( tanabe sustec pros 2/3 the way down).. after over 1 and a half of heavy sport driving on rough roads havent had a problem yet.. all my friends say im lucky... i think im just gonna save up for the comptech combo
Old Feb 10, 2005 | 04:52 AM
Honda Hick's Avatar
Default Re: itr swaybar & beaks kit (sleeperciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperciv &raquo;</TD></TR><TR><TD CLASS="quote">If you want to protect the subframe damage then get this: http://a-spec-racing.com/products.php
I don't trust the beaks kit after one of two people on this site showed a beaks kit w/ ITR sway bar with a torn subframe. </TD></TR></TABLE>
For the $180 that the A-Spec deal costs plus an ITR rear sway bar you could go ahead and get the Comptech kit though.
Old Feb 10, 2005 | 10:24 AM
dohcroc's Avatar
Default Re: itr swaybar & beaks kit (Honda Hick)
so if i run the beaks with mountig hardware i would be fine running the itr sway and about abs im lacking it so ill be good
Old Feb 11, 2005 | 09:15 AM
AFTERZERO's Avatar
There are numerous of people running the beaks kit, I would say the reason any problems with the kit would be caused by bad install.
Old Feb 11, 2005 | 09:20 AM
willieB18C's Avatar
Default Re: itr swaybar & beaks kit (AFTERZERO)
The spot welded nuts are a bit of a pain in the *** to get out, but I found that the set up really stiffened up the rear of my car
Old Feb 11, 2005 | 10:10 AM
etv23's Avatar
Default Re: itr swaybar & beaks kit (willieB18C)
I've got the beaks kit with the itr sway bar for about 4 years. Been auto x'ing with em and riding em with twisties. no problems at all
Old Feb 11, 2005 | 10:16 AM
RuskeR's Avatar
etv24, how low is your GSR? This is the only other mod I haven't gotten around to buying for my 00.
Old Feb 11, 2005 | 10:55 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: itr swaybar & beaks kit (njandrewg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by njandrewg &raquo;</TD></TR><TR><TD CLASS="quote">i hear you can't use the BSQ kit if your car is lowered more than 2 inches, because u'll be damaging your abs lines</TD></TR></TABLE>
I did run the BSQ kit for about 1.5 years with a ~3" drop, and it did rub the ABS wire protectors (made little flat spots on them) but did not damage the actual wires.
Several months ago I switched to the Beaks kit, no real reason other than I just happened to have the money sitting in my PayPal account already, and no problems with that, either.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperciv &raquo;</TD></TR><TR><TD CLASS="quote">integra and civics have the same chassis.
meaning EVERYTHING are interchangeable except the some parts of the ITR</TD></TR></TABLE>
I think that EG kit just came out recently on the A-spec Racing website. They didn't have it when I looked at that site a few weeks ago. I'm pretty sure the EK stuff will NOT work with a DC chassis (I know the EK Beaks kit is quite a bit different from the EG/DC kit). Actually they don't even have the page working yet for the EG kit, so they might not even have it ready to sell yet.
Old Feb 11, 2005 | 11:32 AM
etv23's Avatar
Default Re: (RuskeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RuskeR &raquo;</TD></TR><TR><TD CLASS="quote">etv24, how low is your GSR? This is the only other mod I haven't gotten around to buying for my 00. </TD></TR></TABLE>
RuskeR
I am running H&R sports, it should be around 2inch front and 1.5 back. correct me if im wrong.
Old Feb 11, 2005 | 12:03 PM
IntegraXTR's Avatar
i have it and love it
no probs here!
Old Feb 11, 2005 | 02:53 PM
dohcroc's Avatar
is the beaks that hard to install that if u dont install it rite something can go wrong i mean it looks pretty strait foward
Old Feb 11, 2005 | 06:06 PM
RuskeR's Avatar
Default Re: (etv23)
Nice, I'm running the same suspension! How do you like it, with the ITR bar and all?
Old Feb 11, 2005 | 08:23 PM
Community Builder
Default Re: (dohcroc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcroc &raquo;</TD></TR><TR><TD CLASS="quote">is the beaks that hard to install that if u dont install it rite something can go wrong i mean it looks pretty strait foward</TD></TR></TABLE>
Yeah but it can be fairly difficult trying to get all the parts assembled together with just 2 hands. When I first put on my Beaks kit, my car was on a lift and my friend held up the swaybar while I threaded the bolts and parts together.
Later when I changed out my bushings from stock ITR to ES, I was at home with just jackstands, and I had to use my other 2 jackstands to hold the bar up to the subframe while I threaded the parts back together.
Old Feb 12, 2005 | 10:44 AM
dohcroc's Avatar
Default Re: (PatrickGSR94)
wheres the cheapes price that i can find the beaks kit for
Old Feb 12, 2005 | 10:54 AM
Community Builder
it goes for around $65 I think.
. o 69 o .
Jan 8, 2003 05:43 PM
grngsr01
Oct 3, 2002 11:22 AM
ndustryalGSR
Dec 15, 2001 02:46 PM
BlueG3Teg
Oct 5, 2001 11:14 AM
Nighthawk GS-R
Oct 3, 2001 10:50 AM
