No power/spark to Motor.
Old Feb 9, 2005 | 06:02 PM
DaMmniTz's Avatar
Default No power/spark to Motor.
Hey, I just finish doing a engine swap. When i stuck the key in the first time, the cluster lights came on. There was power! But the car didn't even start up even when the clutch is done. So i went back and reconfigurate the battery wires (+,-) and now there's no power at all. I hook it to a different battery and still no power?
This is my first swap. So you know that feeling when your about to start it up for the first time hoping it works? I got that feeling but the opposite.!!
What should i check next?
Old Feb 9, 2005 | 06:09 PM
CRXDrew's Avatar
Well.... does the main relay click?
Check to see if the starter is good?
Blown fuses?
Old Feb 9, 2005 | 06:15 PM
DaMmniTz's Avatar
Default Re: (CRXDrew)
On the right hand side of the engine, the fuse box. My positive wires is hooked up to crapload of bolts on the tranny. About 3 bolts. Why so many?
Old Feb 9, 2005 | 06:17 PM
DaMmniTz's Avatar
Default Re: No power/spark to Motor. (DaMmniTz)
Can someone explain how the battery wires are connect? And where they go also would help.
Old Feb 9, 2005 | 08:14 PM
DaMmniTz's Avatar
I got the power to turn on. But it trys to start cause the engine shakes, but it doesn't start. So what is next to troubleshoot?
Old Feb 9, 2005 | 08:23 PM
turbodcivic510's Avatar
check if you getting spark, if not start with your distributer/and or ignitor
Old Feb 9, 2005 | 08:33 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
The red terminal goes to the positive side of the battery,
The wire coming off of it goes to the very first terminal inside the underhood fuseblock..
Old Feb 9, 2005 | 08:36 PM
nice job with the pic man!
Old Feb 9, 2005 | 09:19 PM
DaMmniTz's Avatar
I got power now, and the engine actually wanna start but it doesn't start all the way. what's next to troubleshoot!? Could it be the si dizzy? Alternator? Anything will point me in the direction of finding out what's wrong.! It has full gas, all gas lines are plugged. What could be wrong!.
It has been: 6 days 12 hours 42 mins counting on my first swap.
HXvtec
Jul 20, 2010 01:56 PM
Turbo Bora
May 15, 2007 08:27 AM
strils
Jan 11, 2007 08:06 PM
lscrxhf
Jul 26, 2006 06:02 PM
