Whats the best $150 you've ever spend in your Integra ? Best Mods <$150.
Old Feb 9, 2005 | 05:35 PM
FireMedic's Avatar
Default Whats the best $150 you've ever spend in your Integra ? Best Mods <$150.
Here's an age old question for car owners. What can I do to my car for not a whole lot of money. Here was my answer!.
Since I bought my teg a bit over a year ago, i've been noticing (more like getting pissed about) the 'bog' that I would get whenever I would start off. It didn't feel like a mechanical problem, but something else. After a bit of research I found out that the motor mounts on my car had seen better days. None of the little rubber arms (I guess you would call them that) were attached whatsoever. After about 30 minutes of research, I found out there were 2 routes for me to go with the repair of my mounts. One option was to replace the whole mounts with OEM style, or, aftermarket polyurethane. Once I checked into this, i found this to be a bit expensive. So with a little more research, I found Energy Suspension Poly Mount inserts for $30-40. I searched through H-T posts, and found that these would solve my problem.
I found out what was involved with the changing of these mounts, and with the whole car jacked up, i figured I would install a shortshifter, with bushings at the same time. I placed an order for the Black Energy Motor mount inserts, a B&M Factory style dual bend shifter, and black energy shifter bushings. I ordered everything from Rob at Robearracing.com for $100 shipped to my door, and patiently waited. to Rob and Robearracing.
I also installed my Brembo blank rotors, Hawk HPS pads, and goodridge stainless braided lines that i've had for about a year, while the car was in the air. With the new mounts installed, I found the car just goes whenever i press the pedal, and has a bit better throttle response. With the new shifter and bushings installed, the shifting also has a better feel, which i expected anyway, since i had the same setup in a other car i've owned.
So thats the best $100 i've spent in my car... but i figured I could hear more stories if i set the price at $150... lets hear your story!
Old Feb 9, 2005 | 05:37 PM
Slain's Avatar
150 dollars worth of maitence is always good. making sure your car has a good clean bill of health
Old Feb 9, 2005 | 05:39 PM
JamaicanDM's Avatar
Default Re: (Slain)
rsr 4-1 headers
Old Feb 9, 2005 | 05:43 PM
i3yron's Avatar
Default Re: Whats the best $150 you've ever spend in your Integra ? Best Mods <$150. (FireMedic)
150 on a dc 4-2-1 ebay baby
Old Feb 9, 2005 | 05:48 PM
jadebellyt's Avatar
ITR 22mm sway
Old Feb 9, 2005 | 05:52 PM
The-LS's Avatar
https://honda-tech.com/zerothread?id=874701
theres a 10 page thread on this already...
Old Feb 9, 2005 | 06:10 PM
FireMedic's Avatar
Default Re: Whats the best $150 you've ever spend in your Integra ? Best Mods <$150. (Black-LS)
I searched it, didnt find anything similar in the teg forum... ::::
Old Feb 9, 2005 | 06:21 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: (jadebellyt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jadebellyt &raquo;</TD></TR><TR><TD CLASS="quote">ITR 22mm sway</TD></TR></TABLE>
That's it, hands down.
Old Feb 9, 2005 | 06:31 PM
JFG Kevin's Avatar
I think ones again the sway board will be it
Old Feb 9, 2005 | 06:44 PM
timmy8151's Avatar
Another vote for the ITR sway. Make sure you get the BSQ kit or Beaks kit too.
Old Feb 9, 2005 | 07:01 PM
Ketone's Avatar
Default Re: (timmy8151)
motor mounts were my best &lt;$150 spent!
Old Feb 9, 2005 | 07:17 PM
njandrewg's Avatar
Default Re: (Ketone)
i got a ITR sway bar...but I didn't install it yet so I can't comment on it yet
but prior to that
ebay strut bar mugen style $25
ebay strut bar type R style $25
ebay strut bar rear mugen $25
ebay intake + filter $25
9005 sylvania cool blue conversion $15
whistler used radar detector $35
Old Feb 9, 2005 | 07:23 PM
DoctorGSR's Avatar
i have a DA so my ST 19mm rear sway bar was my best &lt;$150 purchase.
Old Feb 9, 2005 | 07:25 PM
94whtgsr's Avatar
flywheel
Old Feb 10, 2005 | 05:28 AM
eymnewdc4's Avatar
Default Re: (Slain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slain &raquo;</TD></TR><TR><TD CLASS="quote">150 dollars worth of maitence is always good. making sure your car has a good clean bill of health</TD></TR></TABLE>
im with you on this one.
but also i have haerd many great things about the sway bars as well.
so to me, either one!
Old Feb 10, 2005 | 08:49 AM
G_S_R's Avatar
Default Re: (eymnewdc2)
yup....ITR sway bar.
R
Old Feb 10, 2005 | 09:06 AM
gsr_to_the_MAX's Avatar
Default Re: (G_S_R)
jdm type r 4-1 headers from my buddy for around 150ish
Old Feb 10, 2005 | 11:34 AM
eymnewdc4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ketone &raquo;</TD></TR><TR><TD CLASS="quote">motor mounts were my best &lt;$150 spent!</TD></TR></TABLE>
what kind? ive been looking for some. but i dont know much about them. and also what about all around bushing upgrades? mine are all 10 years old!
Old Feb 10, 2005 | 11:39 AM
BlackSage's Avatar
used comptech icebox.
Old Feb 10, 2005 | 12:16 PM
uzabatty's Avatar
security
Old Feb 10, 2005 | 01:08 PM
IggyBcool's Avatar
so whats the difference between the itr sway, and an after market one? after market as in not some el cheapo off brand
Old Feb 10, 2005 | 01:22 PM
95lstegman's Avatar
Default Re: (99LStegra)
hands down, baby. more power is nice, but these cars handle better than they go, so i stick mostly with the handling department, making just enough power to smush some ricers into the ground. oh yeah, and get from corner to corner.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99LStegra &raquo;</TD></TR><TR><TD CLASS="quote">so whats the difference between the itr sway, and an after market one? after market as in not some el cheapo off brand</TD></TR></TABLE>
i don't think there are any "el cheapo" types. but several aftermarket makers use 19mm bars, like Suspension Techniques. theirs might be the same, since it has polyurethane bushings. i don't think there are any available for ITR rear sway. i tried getting Energy Suspension 22mm front sway bar bushings, and they didn't fit the rear since it has a difference bracket.
of course, my opinion on getting the 22mm rear bar as #1 priority only applies if your car has all its maintenance caught up. otherwise, you're neglecting your maintenance, and you're either stupid, a ****, or you just plain don't belong near a car in the first place.
Old Feb 10, 2005 | 01:45 PM
marsbike's Avatar
From: Salt Lake City, Chicago at heart, UT or IL, USA
yet another vote
Old Feb 10, 2005 | 02:00 PM
blacknbean's Avatar
the comptech sway/tie combo works just as good if not better than the ITR sway, its just thats its $300+ where the itr is less and a $100. the price difference probably doesnt justify the performance gain so the itr is a good deal for now
Old Feb 10, 2005 | 02:15 PM
IROSOLO's Avatar
Default Re: (blacknbean)
Use the $150 you have and buy a shotgun and put that piece of **** to sleep!
