any honda transmission pros online?
Old Feb 9, 2005 | 05:14 PM
vtec-adykt's Avatar
Default any honda transmission pros online?
the reason i ask this is because i have a slight problem. i own a 1992 honda accord dx with an automatic tranny that i purchased about 2 months ago. when i got it, i noticed that the tranny kinda hesitated when shifting into second gear, then when it finally engages, it does so kinda rough. first i thought it was just the mounts, but i checked em and look o.k. Then about a month ago, the "D4" light on the speedometer started flashing every time i drive it. any idea what it could be? by the way, the car has 222,000 miles on it and counting. so ive got nothing but respect for it. I need to keep it running, so any and all help is greatly appreciated. thanks.
Old Feb 9, 2005 | 08:56 PM
PrettyLude's Avatar
your tranny is about to die
Old Feb 9, 2005 | 09:55 PM
Lord Helmet's Avatar
Default Re: (PrettyLude)
sounds like a rebuild job to me.
Old Feb 10, 2005 | 06:48 AM
PrettyLude's Avatar
pm gearspeed on this board he works with honda trannys all the time
Old Feb 10, 2005 | 07:24 AM
Gearspeed-Performance's Avatar
If you have that kind of mileage on the trans I would suggest a reman unit. Your original trans has had better days and its time for the retirement home You can try to troubleshoot with electronics but, with the mileage alone...I would do the reman.
Old Feb 10, 2005 | 07:59 AM
JimBlake's Avatar
Default Re: any honda transmission pros online? (lazyeyez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazyeyez &raquo;</TD></TR><TR><TD CLASS="quote">... the "D4" light on the speedometer started flashing every time i drive it...</TD></TR></TABLE>It sure wouldn't hurt to read any error codes before you panic & buy a tranny.
Old Feb 10, 2005 | 09:41 AM
vtec-adykt's Avatar
Default Re: any honda transmission pros online? (JimBlake)
i read the error code but i cant tranlate it . i used the jumper wire metnod on the service connector. when i did so, the check engine light stayed on, and the "D4" light blinked 7 times. it would stop, then blink 7 again. what code is this?
Old Feb 10, 2005 | 09:56 AM
_BEN_'s Avatar
Have you ever changed the fluid/filter?
One time one of my jackass friends drained the tranny oil out of his car thinking he was doing an oil change. Then he went ahead and added new oil to the engine wich allready had pleanty in it. LMFAO
Needless to say the car shifted very abruptly and irraticly with no fluid in it. Fluid and a filter is probably less than 40 bucks.
Old Feb 10, 2005 | 10:09 AM
vtec-adykt's Avatar
Default Re: any honda transmission pros online? (_BEN_)
i didnt know that hondas had tranny filters.
Old Feb 10, 2005 | 10:48 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazyeyez &raquo;</TD></TR><TR><TD CLASS="quote">i didnt know that hondas had tranny filters.</TD></TR></TABLE>I don't think they do...
Tranny code 7 is probably shift solenoid B or something useless like that, if you only want the code description. For details of EXACTLY what to check out & how to do it, get your hands on a Helm book for your year.
Old Feb 10, 2005 | 11:44 AM
_BEN_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">I don't think they do...</TD></TR></TABLE>
They have them
http://www.bulkpart.com/Mercha...nda4f
item 6/8 http://www.hondapartssource.co...ch=no
item 4 http://www.hondapartssource.co...ch=no
Those are for the accord btw. I just found whatever came up first I am sure you can get more competitive prices at autozone or elsewhere online.
Old Feb 10, 2005 | 11:56 AM
Points to shift Solenoid A and if no fault is found then to swapping control unit with known good one. They have filters but are not changed like you think. Only on rebuilds.
Old Feb 10, 2005 | 12:09 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: any honda transmission pros online? (GearSpeedEF9)
i love gearspeed trannies
senko14
Jun 29, 2012 12:26 PM
jdm_dc_fan
Honda Civic (2006 - 2015)
Feb 10, 2008 06:41 PM
GEIJIN
Aug 22, 2007 04:00 PM
dlowdog
Jan 31, 2007 07:13 PM
jdm_nothing
May 16, 2004 04:08 PM
