Quality coilovers that will give decent ride comfort
Old Feb 9, 2005 | 04:47 PM
Playa_FL's Avatar
Default Quality coilovers that will give decent ride comfort
What company makes a coilover kit that will give decent ride comfort? Right now I bought a coilover kit off of ebay and the springs are stiff as hell. I would like to know what I can buy that will give me a more of a comfortable ride but not be too stiff????
Old Feb 9, 2005 | 04:53 PM
ukdm crx's Avatar
Default Re: Quality coilovers that will give decent ride comfort (Playa_FL)
Tein or omnipower would be good but you'll pay the price.
Old Feb 9, 2005 | 06:11 PM
CRXDrew's Avatar
^ yep.
You can get some ground controls and some nice dampers instead.
Ebay coilovers r junk.
Old Feb 9, 2005 | 06:15 PM
HatchBox's Avatar
Skoobie no more...
Default Re: (CRXDrew)
ground controls with custom rates
Old Feb 10, 2005 | 10:07 AM
Playa_FL's Avatar
Default Re: (HatchBox)
Thanks guys. What are rates??
Old Feb 10, 2005 | 10:10 AM
EP3_05's Avatar
Default Re: (Playa_FL)
Spring rates. They are measured in units of force per length. The definition of stiffness is the amount of force required to displace a body a certain distance. Divide the force by the displacement and that is your stiffness.
For example: a 450 lb/in spring requires 450 lb to displace the spring 1 inch.
Old Feb 10, 2005 | 10:30 AM
CRX Toad's Avatar
Default Re: (91civic)
Another thing you can with coilovers is use 89 accord struts because they bolt in and are shorter than the our Civics/CRXs, that way it utilizies the stroke instead of already having a compress stroke out of our stock ones
Old Feb 11, 2005 | 09:32 PM
Playa_FL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civic &raquo;</TD></TR><TR><TD CLASS="quote">Spring rates. They are measured in units of force per length. The definition of stiffness is the amount of force required to displace a body a certain distance. Divide the force by the displacement and that is your stiffness.
For example: a 450 lb/in spring requires 450 lb to displace the spring 1 inch.</TD></TR></TABLE>
So what would you say the spring rate is for a stock spring?
theciv
Honda Civic (2001 - 2005)
Jun 18, 2008 08:55 PM
kixcrx
Suspension & Brakes
Feb 16, 2007 07:19 AM
jetpilot
Suspension & Brakes
13
Oct 24, 2006 08:48 PM
ProJectCvic
Apr 28, 2003 09:03 PM
allmotorEG-SI
Oct 16, 2001 05:41 PM
